โJan-08-2016 10:48 PM
โJan-12-2016 01:47 AM
โJan-11-2016 08:22 PM
โJan-10-2016 03:55 PM
โJan-10-2016 09:43 AM
โJan-10-2016 09:28 AM
maxmorrow wrote:
I have a B&W companion hitch and only thing we could see was that the jaws are thicker than on most other hitches. I hated to take it off because it really worked great when towing.
โJan-10-2016 07:20 AM
RustyJC wrote:
Actually, e-trailer lists the material of the Reese disc as being nylon.
โJan-10-2016 05:34 AM
โJan-10-2016 04:31 AM
โJan-09-2016 09:26 PM
greende wrote:Old-Biscuit wrote:
They are not 'plastic'
They are Teflon hence the lubricating properties
*Allows the hitch head plate and the pin box plate to slide up over each other when hitching up (pin box plate lower than hitch head plate------eliminates high hitching)
*Allows the pin box and hitch to rotate on each other when making turns
Teflon plate replaces the need for greasing the plates.
They come in different thicknesses and dimensions
Greasing of king pin/hitch jaws still a good idea due to metal/metal contact.
OB, the type of plastic doesn't really matter, but I think you will find that the disks are made of High Density Poly. Same thing the machine slides and snowmobile slides are made of. Does the same function that you so expertly outlined, however.
โJan-09-2016 06:17 PM
โJan-09-2016 03:04 PM
โJan-09-2016 10:12 AM
โJan-09-2016 06:37 AM
โJan-09-2016 04:54 AM
โJan-09-2016 04:31 AM
