โAug-02-2015 04:27 PM
โAug-12-2015 06:05 AM
shadows4 wrote:
I use the Level + by Hoppy. You adjust the smaller level to level before you unhitch. Then when you go to hitch back up just raise or lower the 5th wheel till the level reads level again. Super simple. Here is a pic of one.
โAug-11-2015 02:39 PM
โAug-11-2015 01:52 PM
โAug-04-2015 05:40 PM
avvidclif1 wrote:rhagfo wrote:
You don't need to have the pin level with the hitch to connect, in fact trying to do that can lead to "High Hitching"! You want the pin plate about 1"'lower than the hitch plate, even up to 2" works just fine! You really want the pin plate ride up the hitch plate a bit the will prevent high hitching.
Unless you have a Curt Hitch. Then it doesn't work.
โAug-04-2015 06:06 AM
fj12ryder wrote:
It would take me longer to try some of these suggestions than just getting out of the truck and walking back to see how far I need to lower/raise the trailer. ๐ I back up until I'm within a couple of inches of the pin, get out and raise/lower to where I want it, then get back in and back into the hitch. No muss, no fuss.
โAug-03-2015 05:18 PM
โAug-03-2015 04:19 PM
โAug-03-2015 03:25 PM
โAug-03-2015 02:45 PM
โAug-03-2015 02:31 PM
โAug-03-2015 01:50 PM
โAug-03-2015 01:11 PM
blacktop wrote:
What about putting a mark on your jacks when you finalize the right height so you know how high to go every time you hook up?
โAug-03-2015 09:23 AM
โAug-03-2015 09:05 AM
Old-Biscuit wrote:Hiking Hunter wrote:rhagfo wrote:
Got to ask why this will not work with a Curt hitch, when it is the recomeded method for all other 5th wheel hitch.
avvidclif1 is right...
The Curt Q20 is a different kind of hitch and is not hitched up like other hitches. Some people who have had other brands of hitches have trouble with this. I did too, until I realized the reason.
Most fifth wheel hitch plates โfall backโ at an angle to provide a โrampโ for the trailer hitch plate to ride up on when hitching. This doesnโt work very well for the Curt hitch because of the way it is made. The Curt hitch has a solid steel shank that is affixed to the hitch plate that extends down into a thick, rigid, rubber mount. This mount provides damping and prevents most โchucking and buckingโ prevalent in many hitches. When the hitch is not coupled, the "resting" or "static" position of the hitch plate is parallel to the ground instead of tilting back like most hitches. The plate does have a slight bevel at the trailing edge of the hitch plate. When you are hitching to the Curt hitch, I have found it is best to elevate the trailer pin so that the hitch plate is almost at the same height as the truck hitch plate โ within ยฝโ. Most other hitches are a little more forgiving on the height because they will elevate the trailer 1-3 inches with the โRampโ.
Not according to the Curt Q20 Owners Manual pg. 3 & 4 'Coupling' Section
Pg. 3
. Adjust the front trailer lifting jacks so the trailer's kingpin skid plate is approximately 1/2" below the top surface of 5th wheel
skid plate. Hooking up in this manner helps ensure proper
engagement of the trailer kingpin to most 5th wheel systems.
Never lower the trailer's kingpin into the 5th wheel hitch head.
Pg. 4
.Back-up the towing vehicle while remaining centered and aligned to trailer's kingpin. The trailer's kingpin skid plate will compress the towing vehicle's suspension and ramp up onto the 5th wheel skid plate
Pretty much sounds like hitching is the same ...trailer king pin plate lower than 5th wheel hitch plate...back in/up onto hitch
Granted the 1" to 2" might be a bit too low for some hitches.....but king pin plate lower than 5th wheel hitch is a good method that will help eliminate some issues
