Question about winterizing with my pump ?
Bigmoss
I bought the Camco RV winterizing kit and watched enough Youtube videos I am confident about doing the winterization myself.
I looked at my pump on the weekend just to make sure in a month or so when Im ready we are good to go and on the inlet side there is a large clear plastic ball threaded over that side. The diameter of the thread looks like it will fit the Camco plastic adapter and valve but Im just not sure. Has anyone seen this type of pump piece I have and any idea with the winterizing kit will work ok ?
Here is my pump
Camco Kit
2016 Ford F-150 Screw Lariat Short Box
2015 Jayco Eagle HT 27.5 RLTS
Reese 30051 Hitch with Revolutionary Pin
11 REPLIES 11
oldtrojan66
My idea is the clear thingy with the ball is some kind of back-flow preventer. Just make sure the arrows are in the right direction and no problem. Glad you got it done.
2007 Jayco Designer 36RLTS
2006 F350 DRW 6.0 PSD (powerstrokehelp.com)
When you're born, everyone is smiling and you're crying. Live so that when you die everyone else is crying and you're smiling!
grampscamper
I just installed that kit today. Works very well. My kit the arrow is pointing away from the pump & don't over tighten the plastic coupler. It took no time at all. Good luck.
2019 Grand Design Reflection 230RL
2020 Ford F250 Lariat CC SB 4X4 6.7 B&W Companion RVK3300
Ed9824v
hammer21661 wrote:
It is a filter got them on most boats too.
my boy had water pressure issues and bought a new put when we went to install it we first removed the round ball and its filter was plugged, we cleaned it and he brought the new pump back.
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
hammer21661
2018 Ram 3500 SRW crew cab long bed 4x4 diesel Lariamie 1-2018
2013 fuzion 322.8/25/2012
2000 Yellow Lab mix Dog, Earl,The One who gave me Unconditional Love picked up 9-12 or 13, 2001 till 2-7-2014 may he r.i.p.
joebedford
Nomad II
Nomad II
Isn't that a check valve?
Johno02
If that is just a filter, I would take it out and throw it away while installing the kit. If you need a filter, get one of the small home filters at Home Depot and use it in your water line. Or, get one of the in-fine filters at Walmart and replace it every year when you de-winterize. If it is a backflow valve, make sure you get antifreeze in it or expect to replace it.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
C_Schomer
When I was in Co, I blew the lines out and stored the pump in the garage. I never had an rv with that plastic filter and never needed one. I've seen water damage in 2 friends RVs from those things cracking. Craig
Bigmoss
Thanks guys, so that clear thing is a pre-filter then ok I was not sure what is was. Hopefully will stay warm enough I will winterize end of Oct beginning of Nov
Thanks
Johno02
Assuming that the part is an intake filter, the kit will go between it and the pump. After bypassing and draining the water heater, put the hose end into a bottle of antifreeze, turn valve to that side, an use the pump to get antifreeze to all your faucets. be sure to do the toilet, and toilet sprayer if you have one. Also the outside shower if there is one. Locate your low-point drains, and open them till they run pink also. I use about 1 3/4 gallons to fill all the lines. use whatever you have left to fill drain traps, wnatever runs into your waste tanks won't hurt. Some folks quit running as soon as pink comes out of the faucet, not thinking that there is untreated water in the drain lines also.
mpfireman
I thought that ALL pumps came with a way that you could winterize your unit without adding anything to it. There should be a shut off valve located at the base of this open ended tube. This valve is closed during everyday use, and only opened when you want to winterize your RV. Winterizing your unit should take less than 30 minutes, but it will probably take you longer the first time as you are not familiar with all of the drain valves.
In the picture, i can see a plastic handle that opens and closes one of your water lines. If you know anyone who has an RV, they could help you locate and ID all of your lines.
1998.5 Dodge Ram Quad Cab Cummins
1998 Sunnybrook 27RKFS Fiver
rvten
Sould be a good fit.
I am guessing the T fitting goes between the filter and pump.
You may have to loosen the pump to allow turning the T fitting on.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is NO B+
