Question before the storm
Trixie47
Since the landing gear is electric what would you do if the motor went out. Suppose you are at a campsite...how to raise it to get it back on the truck, or better yet....what to do so you can take it off the truck...Trying to get a jump on something that hopefully may never happen...
2008 Chevrolet Silverado Crew Cab DW
2012 Keystone Avalanche...4 Slides
16 REPLIES 16
Devocamper
On our fifth wheel we had a hand crank for each of the front jacks and the slides were hydraulic and had a hex fitting on the end of the pump with a valve you could change the position of to either open or close the slides, you could run the hydraulic pump with a cordless drill to get the slides in or out, our current truck camper jacks can be moved with a 3/8 inch ratchet or 3/8 extension
08 NU-WA Hitchhiker Discover America 339 RSB Sold
18 Host Mammoth
07 Chevy 3500HD LT1 EXT Cab LB DRW D/A Sold
18 Ram 3500 SLT Crew Cab DRW 4x2 6.4 4.10's
austinjenna
My landing gear motor recently went out and I used the hand crank. Granted I cranked for a while but I didnt think it was hard to crank at all. Maybe others have had a broken gear or something which made it harder for them to do.
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
cummins2014
As said the hand crank is an option, have used it to see how it goes, not easy, but doable.
What I wasn't prepared for is when the curb side bolt came out of the drive line, and only the drive side landing gear was moving, the problem is I have an onboard generator , so now no way to get to that bolt. Sitting in an RV park, and no way to raise the fifth wheel, had to go buy a sawsall , and cut a hole in the propane compartment to access the driveline, and replace the bolt, but I did have a replacement bolt, and now a spare sawsall ๐Ÿ™‚
GHop
BB_TX wrote:
Roger10378 wrote:
There should be a crank and a place to insert it so that you can manually raise or lower the landing gear. Mine is in the propane compartment on the drivers side.
Same on mine.
same here
G.H.
Me_Again
Lippert Level up comes with a flexable drive to operate the pump with a drill. On our older Cardinal the slide pump could be run with a drill and hex drive. However you had to jumper the control solenoids with a 9V battery, so you need 4-6 hands.
Mike_LeClair
I tried to do the manual cranking thing when our gear casing broke and would no longer engage the jack leg post so as to hold it in place. It just flopped around in the propane cabinet. What a giant POC those things are and they price them like they are titanium. ANYWAY, I grunted on that crank until I thought I was going to blow a heart valve and realized that I had raised the RV a mere 1/4" or so. I gave up on that idea and just used my 20T and 12T bottle jacks to lift the RV off of the truck and get it level.
Cheers!
Mike
Something Old, Something New
2012 F350 SRW, 6.7l Powerstroke, 3.55's front and rear.
2008 Fleetwood Regal 325RKTS
Mike, Carol and our 4 legged "furry child" Kenzie Shweenie Tod
Wild_Card
I carry 2 bottle jacks. That manual cranking of the landing gear, I have done it twice 1st and last.
I would suggest you try it once...eat your Wheaties 1st
2015 Ram 3500 Dually
Sundowner 2286GM Pro-Grade Toyhauler
memtb
Not completely understanding the question! Do mean a power failure....as in no 120 volts to the campground, or your 12 volt camper system failed?
โ€œIfโ€ you mean, campground power, no problem! The jacks work off of the 12 volt system. Unless....youโ€™ve depleted your RV batteries after the campground failure. Then .... you go to the suggestions by others!
This, is one of those situations where a generator ( even if only 1000 watt) could make things.....less โ€œunpleasantโ€!
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
the_bear_II
X-4 on the crank. Have used it on more than one occasion when the batteries were dead and I didn't have time to recharge them.
I seem to remember one time when the landing gear clutch broke and the crank would not work. I used a floor jack on the frame to raise the 5th wheel to hitch it up. The dealer replaced the landing gear (under warranty).
BB_TX
Same on mine.
Neal_B_
Do you have the automatic leveling? If you do then there should be a screw on the end of the motor that you can turn.
2016 Keystone Laredo 297SRE
Andersen Ultimate
2002 Chev. 2500HD Duramax/Allison/4x4
There SHOULD be a manual override crank point. Look for that, possibly in a propane cabinet, or storage compartment.. Somewhere on the side of the camper in line with the jacks...
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Merrykalia
That's what I have Coach-Net for! In all seriousness, we had an electrical problem last year and I called our dealer and he said to use our Coach-Net that came with our purchase. He said they would send someone that could handle it. I don't know where they would find someone, but that's what I was told.
We ended up calling a friend, who was an electrician and he rigged something for us and we were able to get some power going and were able to bring in the awning, bring up the levelers and hook it back up.
2017 Ford F350 Crew Cab 6.7L 4x4 DRW
laknox
x2 on the manual crank. My old Komfort had an access port inside the locked cover for the jack switch. I was told that a lot of people would buy an extra crank and cut it off so they could chuck it up in their cordless drill. :B Need to re-RTFM on the new trailer more closely to find where the manual accesses are for the new one. With separate motors, it would make life =real= interesting if I ever had to do a manual raise/lower.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
