RV Washer feet anchor—where to buy?
lakeside013104
Got the DW a new washer unit for our 5er as a Christmas gift. Do folks anchor their washers to the floor to prevent movement and where do I purchase this anchor?
Lakeside
15 REPLIES 15
Gsport
I got mine installed on Monday, no anchors, it sure feels solid sitting there..
lakeside013104
Thanks Atom Ant.
Lakeside
Atom_Ant
If you scroll down to MK01 on the Splendide accessories page below you will see a PDF for installation:
Accessories
Dryers has them online here:
MK01
When ours were stacked in our Montana in a closet, I installed them front and back (pre-mounted in back then slid the washer into them) because some of the folks had problems with them tipping and breaking the closet door on acceleration.
They are in a slide in the hall now side by side, and they aren't going anywhere. They sit in a recessed place in the floor and no where for them to go.
2008 Ford F350 2014 Redwood 36RL - Our Rig
Onan 5500, Splendide Ariston W/D, 8K axles, disk brakes, G614s, tri-glide pin box,
6-pt leveling, dual heat pump, dual awnings, Trav'ler SK-1000 Dish
jnharley
Ours is also not anchored and no issues. We did have a drain pan installed with a drain out the bottom of the RV in case of an overflow. Our units are stacked in a closet on the curb side of the RV.
2015 Dodge Dually
2012 NuWa Discover America 355CK
Nolan
Gsport wrote:
I'm having a washer/dryer installed in 4 weeks, CW told me they don't anchor it. Hmmmm?
Ours hasn't been anchored down since we got it in 2004. Never even thought of anchoring it down.
bucky
I'm leery of something as big as a W/D being loose in our 5er. In the wrong circumstance it could come thru the front cap or the side wall and make matters worse.
Puma 30RKSS
48ford
If I got DW a washer for Christmas, I would be stuck in there to hold it down. 😉
2005 GMC Sierra 2500HD EC/SB 4x4 Duramax/Allison Onyx Black
DeeZee SS Nerf Bars Line X
2006 Open Road 349RL3S-5
Atom_Ant
Got mine from Splendide when ours stacked. Now that we have them side by side in this rig, I never put the holdowns on.
Vulcaneer
CW in North Conway, NH did mine. They installed the Splendide hold downs. But I ordered them from Splendide and brought them to CW when they started the install. They had no problem with that. Their installer hadn't seen them before. They had no information that would let them order them.
'12 F350 SB, CC, SRW, 6.7 PSD, 3.55 RAR, 6 spd auto
2015 DRV 38RSS 'Traditions'
Pullrite Super Glide 18K
Retirement = It's all poops and giggles....UNTIL someone Giggles and Poops.
Michelle_S
We have a Splendide and got them direct from them. Slips over the front feet and then screws to the floor.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Gsport
Gemstone
I went over the top and down thru the floor with 2 cargo straps. The ratchet and an eye were welded to the metal frame under the closet floor. Neither the washer nor stacked dryer have moved in 7 years.
Regards
Gemstone
'06 Elite Suites TK3, '95 KW T-600, '08 Softail Classic , '06 Softail Deuce
JOHNL
MY hold downs came with washer
lakeside013104
Thank you crickeydog. I was trying to make this too difficult.
Great idea.
Lakeside
