Shackles, springs, etc.
dave14117
Our 07 Carriage Cameo tows nicely. But with about 27K miles on it, I wonder if there's anything that needs to be checked as far as the suspension is concerned. Any regular service required? Brakes have been checked and serviced.
Thanks,
Dave
6 REPLIES 6
Gib3633
Our 2010 Montana also had all of those problems. Long story short if you have a heavy trailer around 15000 lbs the only way to stop the problem is to take it to Mor/yde in Elkhart Indiana and let them install the IS suspension . That eliminates axles and springs and undersized bushings all at once. Their IS suspension is all fully adjustable and includes shock absorbers. I found them very honest and very fair to deal with. We also had them install disc brakes at same time WOW. I believe Cameo offered the IS suspension as an option as a friend of mine had it on his.
Cummins12V98
Keep an eye on the suspension, friends have about the same era Cameo and they had sagging/broken springs and the axles actually beat a mould of the top of the axle in the frame where the axle was pounding up into the frame. They added wet bolts and new heavier rated springs.
I was shocked at the carnage under there.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
SDcampowneroper
Our '09 Carriage had major wear in the shackles & moryde equalizer after 15k miles. I replaced the shackles, put in wet bolts, welded a sleeve through the oval worn bolt holes in the equalizer.
john_bet
My '05 Montana has about the same mileage on it and I just had the springs, equlizers and shackels & hardware replaced as they were completely shot. It pulled good also, but tires on rear axle showed signs of something wrong.
2018 Ram 3500 SRW CC LB 6.7L Cummins Auto 3.42 gears
2018 Grand Design 337RLS
Jack_in_Alaska
Don't forget to service the wheel bearings.
2004.5 Dodge 3500 CTD 325/610 Laramie DRW 4x4 6spd 3.73
Smarty Jr; HiJacker Hitch;TrailAir pinbox;Prodigy;PacBrake;
Access cover;DeeZee;LightForce road lites; Westach EGT/Boost
2012 Jayco Jay Flite 40FER Bungalow TT
Yamaha 3000 iSEB gen.
Old-Biscuit
It's always a good idea to check spring eye bushings for play & any signs of oblonging.
Check shackles for any bending, cracked welds
Look for spring pack sagging/lack of arch. Check spring pack for any leafs shifting/loose-missing bands------cracked springs
Check u-bolts...spring perch for unusual marks.
Braking wiring/condition of insulation/connections for corrosion
Just a few of the things I look at when servicing my trailer.
