Slider Hitch Required?
bodacious
Thinking of trading the '03 GMC 3500 for a 2014 GMC 2500 standard bed (6 1/2 ft.) Will my 16K fixed hitch work with the '05 Cougar 309EFS or would this setup require a slider?
Bodacious & Bride
'00 Northern Lite 10-2000 RR
'06 Escalade CK
'03 GMC 3500 Duramax
30 REPLIES 30
wandering1
Simple answer. The answer is yes if you dont have an 8ft bed and dont want the risk of crashing the 5er into the back of your cab.
HR
Hannibal
With our light weight 5th wheel, I have a second set of bed rails that puts the pin 52" from the rear window or 12" behind the rear axle of our F250 CC SB. I can't tell the difference towing except that I can make full lock U-turns now with no worries. I don't recommend this as it goes agains all the manufacturers recommendations for loading a vehicle. So does loading the trunk of the car with groceries but some folks do it anyway. All I'll say is it works great for "us". Some of the campgrounds we frequent are pretty tight and require some sharp maneuvering to get into a spot between the trees.
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
Scott_85
dballentine wrote:
Scott_85 wrote:
I just found out something today. I just got my camper and my wife picked it up and found that we can't use the sider on my truck. The way the pin is set up it would it the tailgate if the hitch was in the back position.
What about dropping the tailgate down?
To be honest I'm not with the camper but I think the tailgate would hit the camper. I will find out more when I get stateside.
TV: 2013 Ram 2500 Laramie, G56, Andersen Ultimate 5th Wheel Hitch.
5er: 2013 Coachmen Chaparral 280RLS
dballentine
2015 Grand Design Reflection 337RLS
2015 Silverado 3500HD LTZ D/A CC LB SRW Z71
Amateur Radio KQ3T, licensed since 1965
Scott_85
billkaufmann
DonPd wrote:
You can install a new pin box the sidewinder style. I have one and it works great. It also takes the bounce out of the ride. It works better than a slider hitch.
Link to pin box
Sidewinder
X2
Tom_Diane
If the Cougar has a fixed position and a 6.5 box, you will be fine.
2112
I have an extended pin box and rounded front cap on my FW. Did I NEED a slider? No. I chose to install a SuperGlide and not worry about it. Set it and forget it, no regrets.
The SG is a heavy beast though, weighing in at 200#'s.
2011 Ford F-150 EcoBoost SuperCab Max Tow, 2084# Payload, 11,300# Tow,
Timbrens
2013 KZ Durango 2857
WeBeFulltimers
If you are making turns going forward or backing that would make the fiver hit the back of your truck you are putting way too much stress on your fiver's suspension. You can turn it into a real twisted mess! Find another way to do what you are wanting to do. A slider will not prevent it.
2012 Ford F-350 PSD SRW ** CURT Q24 ** 2018.5 MONTANA 3791RD
Passin__Through
tsetsaf wrote:
Wow surprised to read the "if you are careful you won't need a slider" comments. A Superglide can be found used for the same price as a standard hitch new. The one time you need to turn tight you will be happy you have it... and you won't have to "be careful".
Boldface added.
Couldn't agree more. We've only had our rig for almost 1 year, made 6 trips, and there have been several instances when I have needed to make tight turns. Having the Superglide made it so very much easier!
2008 Chevrolet 2500HD Duramax 4x4 CCSB; Superglide 16k hitch w/3" lift kit; Titan 52-gallon replacement fuel tank :C
2007 HitchHiker II LS 26.5RLBG Mor/Ryde pinbox:B
tsetsaf
2006 Ram 3500
2014 Open Range
"I don't trust my own advise!"
Willcamp4
I have always towed using a short bed pickup. I use an extended pin box on the fifth wheel and make sure I am careful not to turn too sharply. It has always worked well. The Cougar has a significant forward rounded shape so that will reduce the turn available before hitting the cab.
Willcamp4
2012 Ford F-250 Super Duty, Crew Cab, Lariat, 6.7L PSTD, Air Lift rear suspension.
Alpenlite Valhalla Limited Fifth Wheel, two Solar panels, four six-volt batteries, two Honda EU2000i generators
shadows4
laknox wrote:
I can NOT hit my trailer, which is very square-fronted, with my '02 D'max and Companion hitch, going forward. It is 4wd, so I =ass=ume that it doesn't turn quite as sharp as a 2wd, but I'm good with my setup. ALL will hit in reverse, just some sooner than others. I =have= taken out my back glass trying to back into a site, so I know my limits and always use spotters when in a tight space.
Lyle
I followed this advice from someone else. I have the old style nose. Never have been
in a situation where I had to use the slider backing up. However I have a nice little crease from turning in our cul-de-sac. Somelse also said you couldn't hit going forward. Guess what? WRONG!!!!!
Get a slider, but use it if things get tight. Good luck, John
2016 4X4 F350,CC,SB,Lariat,6.7L diesel,
2015 Coachmen Chapparal 324 TSRK
B&W Patriot 16K hitch.
DavinD
kmbelt wrote:
I have a 6.5ft bed. I have a slider. I have NEVER had to use it as of yet. If you are careful and pay attention, it is not necessary.
X2
2018 Coachman Chaparral 381RD
TV - 2013 Ford F350 Diesel SRW 4x4 Short Bed
