May-25-2014 05:58 AM
May-27-2014 05:51 AM
May-25-2014 09:09 AM
May-25-2014 09:04 AM
Drought Buster wrote:Then you need to go to my forums, my preferences and click 'Show images that are part of posts.'
Roy, the picture you posted would not open...
May-25-2014 08:47 AM
bfast54 wrote:
Another remote possibility...Battery worn out.....Check water level,and if possible....Volts with a load on it.
At this age,4 plus years,batt could be weak.you just never know how good a battery is so if you do the other things also check the battery.
battery could be about 5 years old in a trailer of your age they dont always put brand new ones in.....the trailer manufacturers buy .... by the pallet load and they could be old
May-25-2014 07:45 AM
May-25-2014 07:36 AM
May-25-2014 07:28 AM
May-25-2014 07:26 AM
May-25-2014 07:06 AM
Rally's attended so far-21
May-25-2014 07:00 AM
May-25-2014 06:58 AM
pianotuna wrote:
Hi,
Check the reverse polarity fuses on the converter.
May-25-2014 06:56 AM
May-25-2014 06:37 AM
May-25-2014 06:32 AM
Mini breakthrough. I flipped the breaker labeled "converter" and heard what sounded like a fan come on. It stayed on for about three seconds then went off. I flipped the breaker, waiter thirty seconds, flipped the breaker back on and, again, a fan or hum for three seconds and it went off. So it sounds like it wants to start but can't for some reason. The problem is I can't find the dumb converter to take a look at it.
