T bucket hot rod in a toy hauler
Brandon327
Does anyone haul a t bucket I there toy hauler? I don't have one but I am thinking about building one. My wife will not ride a motorcycle but is interested in the t bucket. If it will fit in my hauler that has a 12' garage I may build me one. They weight anywhere from 1500 to 2000 pounds. Depending on how they are equipped.
2013 gmc 3500 hd cc Drw 4x4
2016 Dutchmen voltage 3990
12 REPLIES 12
jmaotto
What about a vintage VW beetle. You will not get wet in the rain.
tchil
http://www.raceramps.com/
These guys make some long ramps for low profile vehicles. If you set your ramp door on a set of these it might give you what you need. They are high density foam and very light weight so easy to setup and take down.
Ty
2018 Ram Cummins Mega
2007 Ragen Blackhawk 36-05
kofire
Should be just fine. Just need to figure out how to decrease the angle on the ramp door which can be easily done
lincster
Weight is no problem
My sandrail is 2800lbs and I drive that right up in my Warrior.
Width at my rear paddles is 94" and I fit in with a little bit on each side.
2022 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
drmopar
I can fit my T-Bucket, (340 Mopar-904 trans), in my Stealth 2812 Toy Hauler. My car is 7 feet 2 inch wide, and 11 feet, 2 inches long. Weight is 1680 wet. With an 8 foot wide door, no issues. It is shorter than my 4 seat Gem electric car that also fits. My garage is 13 feet plus. I do have the "Turtle Deck" on loading. Good luck!
nayther
Stock width they're pretty narrow (we have a full fendered '26) but "T-Bucket" like Grabowski's usually run pretty wide rear tires. I know ours won't make the ramp transition, have trouble just getting it on a car hauler.
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
Gonzo42
The famous "Kooky" T-bucket by Norm Grabowski
MOTHER SHIP Winnebago View 24H (2007 Dodge Sprinter 3500 Chassis, 2008 Body)3.0 L M-B Diesel V6 bought used with 24K miles. Toad: ROCKY the Flying Squirrel.
fj12ryder
I don't know that there is a standard. It would depend on the width of the rear end, and the size of the tires mostly. And that would depend on the style of your hot rod. Some like really wide tires, some like the more traditional old style narrow tire.
Howard and Peggy
"Don't Panic"
Brandon327
Some are lower than others. I am concerned with the width, I am not sure how wide they are.
lawnspecialties
Aren't T-buckets fairly low to the ground? My concern there is will it clear the bend where the ramp meets the garage floor?
Brandon327
I meant t bucket hot rod
GordonThree
OK I'll bite, what's a hot T bucket?
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
