Toy hauler on a gasser?
gattorgetter
Looking at the lighter toyhaulers. Right now I cannot justify the extra cost for the Duramax (will only buy GM as I work there). Traveling mostly in Michigan. Looking at 1 ton ccsb...
Would only travel 8-10 times a year
Thought's?
14 REPLIES 14
LVJJJ
I consider the 6.0 more a more powerful puller than the old 454, had both.
We had an '05 Roadtrek Class B motorhome on the 3/4 ton (2500) Chevy Express chassis. I weighed it, was 8000 lbs. We towed a 5500 lb travel trailer with it and it charged up mountain passes easily with 3.73 gears. I was amazed.
1994 GMC Suburban K1500
2005 Trail Cruiser TC26QBC
1965 CHEVY VAN, 292 "Big Block 6" (will still tow)
2008 HHR
L(Larry)V(Vicki)J(Jennifer)J(Jesse)J(Jason)
akcooper9
gattorgetter wrote:
6.0 gas on both 4.10 rear end.. payload varies
Having had a 6.0 and towed with it, I consider that a 10,000 pound max trailer tow vehicle.
gattorgetter
akcooper9
gattorgetter wrote:
My bad I meant to say that I am looking at 5th wheel toyhauler's
What motor is in the 1 ton Chevy?
gattorgetter
atwowheelguy
Thought's?
How many people in your traveling party?
I'm towing a 7765 GVWR TT toy hauler with a 3.5 Ecoboost F150. Cruiser RV Funfinder Xtra XT-245. Could sleep 4 adults and two kids. Four total is probably the practical limit. Tiny bathroom.
Actual weight 7240. Uses up 80% of the 1607 lb. payload.
2013 F150 XLT SCrew 5.5' 3.5 EB, 3.55, 2WD, 1607# Payload, EAZ Lift WDH
Toy Hauler: 2010 Fun Finder XT-245, 5025# new, 6640-7180# loaded, 900# TW, Voyager wireless rear view camera
Toys: '66 Super Hawk, XR400R, SV650, XR650R, DL650 V-Strom, 525EXC, 500EXC
valhalla360
Nomad III
Nomad III
Define "light" toyhauler.
Gas engines can pull an awful lot of weight compared to engines from 20-30yrs ago.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Peg_Leg
Sad day when GM ditched the big block. My 12 dually with the 6.0, 4.10 gears and 6 speed tran has the max 5er around my 13.5k trailer. It's been to long since I looked at the numbers. It handles the unit fine but getting used to the high revs took awhile. Check the numbers in books and make sure you check the rear end ratios. You'll probably not find the lower gears on the lot. I ordered mine and it only took a month to get.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
2019 Open Range OF337RLS
Yamaha EF3000iSE
retired gadgetman
Ductape
You will hear moans from the diesel fandom. There are many of us moving a lot of weight in motorhomes every day with gas engines. The current gasoline Chevy has about the same power as the Ford V10. You'll be fine.
49 States, 6 Provinces, 2 Territories...
lincster
Get a gas card that will give you points. LOL
2022 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
bpadamson
Fiver or TT? We pull a fiver with max load of just under 12,000. We are out in the mountains and spend some time at 45mph on steep inclines. But it tows great as we have it set up.
2013 Ford F250 4X4 6.2gasser--- 4.30 gears, SCT Flash chip, improved tires, airbags; intake and exhaust opened up a bit.
9.5-year-old Forest River 295 WP Toy Hauler
B&W slider hitch
azdryheat
You'll notice the need for a diesel on the mountain grades. Staying in Mich you shouldn't have any issues towing with a gasser.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
Sandia_Man
We live and do most of our RVing here in the mountain west and four corner states, we have a 33' TT toyhauler that comes in at 10K# when fully loaded with toys and water. Our 3/4 ton Chevy Silverado 4x4 gets us everywhere we need to go, which is primarily high elevation camping.
Yeah, it revs up pretty good to get over some of the steep inclines, and yeah it can get quite thirsty doing so, but it is dedicated to hauling our rig around and just sits in the garage awaiting duty otherwise, works great for our situation. She loves to work and has always delivered.
the_bear_II
You need to choose a toy hauler first then get a truck with capacity to tow it. You want a truck with extra capacity instead of getting something that is nearly maxed out.
Gassers will do fine as long as you're not close to maximum tow/cargo capacity.
I towed a 15,000 lb 5th wheel for years with a 1986 chevy gas 1 ton dual cc long bed with no major problems. On a 6% grade I would climb in first gear at 25MPH. Today's gassers have a lot more power than my 1986 truck did.
