โJun-25-2014 06:56 AM
โJun-30-2014 08:55 AM
kakampers wrote:
I will have to dig up my literature. I remember it needing to be greased every 500 miles. Still a combo of the MorRyde system and the Trail/Air air bag system would be great. Hope Lippert can figure it out.
โJun-29-2014 10:03 AM
lillyputz wrote:
I had the Tri glide on the last 5er and have the MorRyde on this one. Hands down on the MorRyde. Best ride ever.
Lillyputz
โJun-28-2014 05:52 PM
โJun-28-2014 09:20 AM
webslave wrote:Cummins12V98 wrote:kakampers wrote:
Just remember...Tri Glide needs to be greased quite often...
True, that's one of the reasons it could be improved on.
It, initially, was a bit of a bother, but, since it only has to be done every 1K miles it isn't a "constant" bother. I got a Lincoln rechargeable grease gun that travels with us and it is only a minute or two, once or twice a week to hit the zerks with a single trigger pull. I work it in with a thorough inspection of the rest of the trailer prior to pulling out. We're retired and usually only cover about 1K miles per week, sometimes is takes us longer to cover a thousand miles, so, it isn't like a "constant" bother. That all being said, though, it would be nice if they could figure out a way to use sealed bearings in the Tri-Glide device to eliminate the greasing altogether. It is much cheaper for them, though, to use zerks and put the onus on the user...
โJun-28-2014 09:09 AM
โJun-28-2014 08:56 AM
โJun-26-2014 02:31 PM
โJun-26-2014 01:58 PM
โJun-26-2014 06:03 AM
โJun-25-2014 03:34 PM
mackyb wrote:
I am negotiations for a new Spartan 1032 FW by Primetime. This FW will push the limits of my 2013 GMC Denali with the Duramax engine. I was planning on adding airbags but my question is, with a Trail Air pin box added & a B&W Companion hitch, would I need to add airbags still with the Trail Air pin box?
โJun-25-2014 02:52 PM
โJun-25-2014 12:49 PM
โJun-25-2014 09:39 AM
โJun-25-2014 08:42 AM
