Water hose size
Bassmon
Does it really make any difference whether to use 5/8 or 1/2 " for the hose size to the FW?
Thank"s
Larry
Larry
12 REPLIES 12
WTP-GC
jacksrbet wrote:
most RV parks have 1/2 suppy line to each site
That's a gross mis-statement. I don't believe I've ever seen anything less than a 3/4" water line. Then they install either a 1/2" or 3/4" hose bib, neither of which has a 100% port (orifice is less than nominal size). But the more limiting factors are pressure and the pipe size in the rig. Volume is based on pressure and if you diminish the pressure, the volume follows. Therefore, on a campers in most parks, I don't see how a 1/8" difference in hose size will be noticeable under 99% of circumstances.
Duramax + Grand Design 5er + B & W Companion
SBGTF
jacksrbet
RollandB
Planning wrote:
Friction loss is a reality, and small differences can create more loss than is intuitive. For example, examine this chart:
I use 5/8" for all hoses, and these for all connections downstream of the park connection:
Yes, size matters.....
Iโ€™ve sat through many classes on managing water losses itโ€™s amazing the difference. I keep two 25โ€™ 5/8โ€ hoses, rarely need to connect the two.
2013 Yukon
2021 Coachmen Spirit 1943RB
allen8106
donn0128 wrote:
Actually it does. Dont believe it, connect each one and test yourself. Half inch would be OK IF you use only faucet at a time. Turn on two, or flush a toilet and watch the flow drop pike a rock. 5/8 might a bit harder to coil up, but you will get better flow.
You are still going down from 5/8" hose to 1/2" pex so there's no difference in volume. the 1/2" pex can only support so much volume. If you hooked a 2" hose to the rig, same affect. The 1/2" pex is only going to allow so much water through.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
Planning
2016 AF 29-5K; 2016 F350 6.7, 4x4, CCLB DRW
MFL
Nomad II
Nomad II
I doubt you would notice the difference between sizes, unless you had a CG with very low pressure. One thing you can notice, is the quality of the hose and fittings, no matter which diameter hose.
Jerry
ScottG
I have both sizes in different lengths and don't notice any difference.
agesilaus
There will be a minor increase in flow rate with the bigger hose but since it is throttled inside the RV the effect is not significant. But be sure to use white or blue potable water hose.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
donn0128
Old-Biscuit
RV Plumbing System....1/2" PEX (0.485 ID)
2oldman
no
azdryheat
Just make sure it is a white or blue hose made for drinking water, not the green hose used at home.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
