Water Pump runs regardless of panel switch position.
rsg63
So this is an odd one for me but thought I would see if it's ever happened to others. Our water pump runs whether or not the water pump switch is on or off. To be clear: I am not saying the pump runs continuously. It only runs on demand like it should. However it used to require that we had the W/P control panel switch 'on' for it to operate. Almost as if the switch has fused the link within itself.
Any thoughts? Am I over thinking this and should just remove the panel and replace the switch? (Just typing this is making me want to go try) 😉
2016 Bighorn/Fuel Rims/Michelin LTX's/MorRyde SRE4000 w/wetbolt kit
4-200AH LiPo batteries/MS2812 inverter/Prog 50A Surge/
8-100 Watt Renogy PV panels/60A Renogy Rover Converter/Reese Sidewinder/
2016 RAM 3500 Cummins MegaCab/45 aux tank/Hensley TS-3 hitch
15 REPLIES 15
dryfly
I would first disconnect the switch(s) circuit at the water pump to determine if the problem is in the pump, or is there is a short in the wiring or a bad switch.
After disconnecting, if the pump continues to run, use an ohmmeter to determine if the switch circuit is closed. If it is then determine if there is a short in the wiring or if it is one of the individual switches.
BigT
The other day I helped a friend with an older Jayco Designer. He couldn't get the pump to stop running. It turned out to be a two fold problem. First of all it had three pump switches that he didn't know about; one on the main panel, one by the bathroom sink and one in the basement on the panel that has the water valve switches on it, and any one of them can turn the pump on. We finally got the pump to stop when we finally found all the switches, but that was only part of the problem. As it turns out the water pump itself was shot: apparently the impeller was either broken or sheared off the shaft. In either case the pump would not pressure up. If yours is cycling on and off then your pump is probably ok. It's either got to be an unknown switch on or a switch that is burned out in the on position. JMHO
2012 Hitchhiker Discover America 349 RSB
Bigfoot levelers, Tailgater satellite
2011 Ford F350 PSD, Pullrite Superglide
RDS Toolbox Tank Combo, Garmin GPS & an itch to hit the road
enblethen
OP: did you check to see if it is a momentery or on/off switch?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
rsg63
Old-Biscuit wrote:
RV Store Direct......lighted rv switches LINK
Factory RV Surplus.........more switches LINK
Thanks Old-Biscuit, I ordered several and will try one as soon as it arrives. Second-outside switch made no difference. 😞
greende
I bet it's the second switch.
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
USAF 1968 - 1972 Viet Nam '71 - '72
ksg5000
Bad switch or maybe the monoplex relay stopped working.
Kevin
midnightsadie
if theres a switch not being used in that panel? use it.
AniJet
Our Place wrote:
Could there be another switch somewhere? Ours has a second switch in the outside shower area.
That's my bet.
07 Mobile Suites 36TK3 Demco GlideRide PIn Box
12 3500HD D/A CC 4X4 AirSafe Hitch
Old-Biscuit
rsg63
It's a on/off illuminated switch. Has worked as intended for 4 years until recently, when the switch light no longer worked and it no longer seemed to actually 'control' the pump availability.
Actually there is a second switch outside, on our outdoor shower as well. Never thought to check that, thanks! If that does not do the trick then I suppose the hunt will be on for a matching switch. Since our panel has about 12-14 identical red iluminated switches on it, I'd rather not have an odd-ball in there.
Thanks for the replies everyone!
enblethen
It could be the switch or the pump controller.
Is this a rocker momentary switch or is it an ON/Off switch?
Bud
USAF Retired
Pace Arrow
Our_Place
2008 Silverado 3500HD crew cab 4x4 SRW Duramax Allison 6 speed
2014 Cougar 327 RES "Campy"
gkainz
First, did it EVER work correctly? If yes, then most likely the switch failed in the closed position.
If no, then PERHAPS the switch is failed, or just not wired in at all?
'07 Ram 2500 CTD 4x4 Quad Cab
'10 Keystone Laredo 245 5er
midnightsadie
so it works normal but runs all the time , I,m bet on the switch.second guess is the pressure switch on the pump.
