water smell
dennyida
Good morning to all from Denny and Ida, We are now camping at our favorite camp ground here in eastern Iowa and we have a problem that We have never encountered. The water that is coming out of the faucets seem to have a sulfur smell to it. I checked the water coming out of the water outlet and it seems to be ok. Out of the faucets it smells like sulfur. Out of the hot water side of the faucets its even worse. We have never used a filter for the incoming water, but I`m wondering if that would help. We only use the city water inlet to our camper which is a 2015 keystone outback 296FRS. Any ideas???? Thank you, Denny and Ida
19 REPLIES 19
laknox
Sometimes the water just stinks, especially if you're near hot springs. We spent a few days at a friends house on the Western Slope of Colorado, near Paonia Reservoir. Water coming from their well just smelled because of the relatively shallow volcanic heating. Leave the water in a glass on the counter for 30 minutes and it is perfectly clear, with no smell. Even smell from the shower went away after a short time. Nuttin' you can do about it 'cept live with it.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
steiny93
drain the water heater and dump your fresh water tank when you put the camper away between uses; problem will be solved
2000 Volvo 610
2013 Cyclone 3950
Kittykath
It's the water heater. No matter what our water source is, it's odorless going in, and stinks coming out. Camper's brand new, nothing wrong with the anode rod, and we have filter upon filter where we can. We've determined it's water sitting in the water heater. We just have to drain the water heater as part of our tear down process.
DutchmenSport
Hey drcook ... please excuse my rambling above. I think I'm a bit confused over another post or something. You're at a campground right now, getting sulfur smell. Sorry ... I'm way out in left field or something on this one.
The sulfur smell is the water. Not much you can do about it. Quick and easy solution (maybe not a solution, but it won't hurt), get one of these. They are not 100%, but sure help a lot: click here
Itching2go
...and one more thought... You might want to make sure that it isn't the water at the campground. We had a similar problem a few years back when camping at Turkey Run State Park in western Indiana. Turned out that the the sulfur smell was coming from the local supply. The local folks had grown used to it, but for us, it was quite annoying. Took a couple of tank drains and flushes of the plumbing before it completely went away. We still camp there on occasion, but now we fill our FW tank with our local water before we head out. Might not be your problem as it sounds like you've stayed at this campground before, but thought I'd throw it out there anyway.
2008 Jayco Designer 35RLSA pulled by a 2007 Chevy 3500 D/A SRW
DutchmenSport
drcook wrote:
yep, I may have it backwards as to the construction, still doesn't change the fact that all RV hot water tanks don't have an anode rod.
ours still smells after filling it up after 2 or 3 days
the only way to keep it from smelling is to use a chemical. our water is not chlorinated. if I filled it from a city faucet I might not have this issue. if the last place anyone fills up is pumped from a well (lots of campgrounds) you can have the same issue. there is going to be bacteria in the water
in fact, every once in a while we have to crack the well head open and sanitize it. every time you work on a well and open the well head, you do the same.
drcook,
Sounds like you are on a private well (not chlorinated). Where I live, I also am on a private well. Our water is pretty bad. Oh, it's 100% safe to drink, it's just so full of minerals it makes you wonder what your drinking.
With that said, we have the same problem you do (even in the house). If our water sits (not just a water heater) anywhere, after just a few hours it begins to smell. Not a sulfur smell, just an unpleasant smell. And, as long as the water is moving, it stays clear, but let it sit for just a few moments, and it begins to turn a grey rust color almost immediately. Not to mention a sediment that sticks to everything, and eventually rust.
We solved all of this by getting a whole house filtration system. We went with Kenetico and also got the water softener too. The system is 2 tanks filled with sand, or something. Water filters through one tank and pulls out all the minerals (and smell). The other tank sits idle. (No electricity at all required for this system).
When the first tank reaches a certain point, It begins to back fill and flushes out all the "gunk" down a drain. The second tank immediately kicks in so you have no interruptions in water supplied to the house. When the first tank is completely backwashed, the backwash stops and the house is using the 2nd tank until it need backwashed when the system repeats itself.
The nice thing about this system is, it only cleans itself, depending upon how much water you use. If you go on vacation or something, it will never backwash. There are no timers, no electricity. It's all run based on your water flow.
The important thing is, we now no longer have the minerals in the water, the rust stains in every sink, toilet, and bathtub in the house, and there is no longer that funky smell.
UNFORTUNATELY! the outside spigot is NOT tapped into the system. It's fed before the filters, so when filling the water tank for the trailer, I have to tap into the water faucet for our washing machine. I put a quick connect on it and it has a Y adapter so I don't have to unscrew hoses this way, just plug the one in.
So, I guess what I'm saying is, if you have funky water in your house, you'll never get rid of the smell in your camper ... until you go camping and are able to hook up to a campground water system.
Whenever we are at a campground and especially if it's city water (chlorinated), I always take advantage of that and flush my lines, water heater, tanks everything. I don't use any chlorine or sanitation methods on any of my tanks or lines in the camper. By taking advantage of chlorinated water (when I'm lucky), has worked pretty good for us for 8 years now (since we've moved into our current house).
The only thing I can REALLY recommend if you are using water from your house to keep the smell out .... Use the water when you are using the camper. When done, drain the water heater. The little bit of water left in the lines will flush right out first time you turn the water back on. But .... definitely ... keep that water heater drained and empty when not in use... until you can find a solution for the foul water smell coming from the house.
From what you described (above), there is nothing wrong with your camper, the anode rod (or lack of anode rod), the water heater, fungus growing in your lines, or anything like that. The source is the water itself. I know... been there ... done that. People on wells are in a different category!
ACZL
Started to have same issue w/ours a few years ago (hot water). Drained/flushed/re-filled at campground....seemed to take care of it. So I thought. Problem came back. Repeated above till next spring. Upon santizing fresh water system w/ chlorine, I filled hot water tank w/ chlorinated water from fresh water tank. Let set 24 hours, empty, refill fresh water tank (after it was drained), fill hot water tank again from fresh tank. Let sit another 24 hours, drain everything, rinse water tank well w/ angled water wand, refill from house and no problems since past 2 years
OP has picked up some bacteria in water tank and more than likely it's contributing to the sulfur odor
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
drcook
2004.5 2500HD CCSB Duramax/Allison - was an Overheater fixed it!!! Bilsteins, Banks stuff, Hellwig Sway bars front and back
2010 Crossroads Cruiser 30QBX
2 Doberman/Rhodesian Ridgeback Crosses - brothers
2 Beagles
1 Shih Poo
1 Shih Tzu
1 Camping Cat
1 wife
LOFAT36
Mine is aluminum, no anode.
Old-Biscuit
drcook wrote:
Doesn't have to be a bad anode in the water heater. We have a glass lined tank. So it doesn't have an anode. Absolutes are never really absolutes.
If I fill the tanks with our water (from a well) it will be smelling in a day or so. That is even a couple days after sanitizing the tank/system getting ready to go.
One absolute that is absolute is if you have a 'glass lined' it MUST have an anode rod because those are the ones that use the anode rod.
Suburban Steel Tank that is glass lined uses an anode rod to protect steel tank from rusting.
Now IF you have an Atwood WH it uses an aluminum alloy tank that does NOT use an anode rod.
Regardless......either brand can get sulfur smell.
Draining/flushing/rinsing usually takes care of that smell.
But sometimes a 'Vinegar Soak' may be required to clean WH Tank.
drcook
2 Beagles
1 Shih Poo
1 Shih Tzu
1 Camping Cat
1 wife
dennyida
Thank all of you for suggestions, looks like I`ve got some work to do, thanks again, Denny and Ida
WyoTraveler
gbopp wrote:
Bad anode rod in water heater?
Yup, correct solution.
edbehnke
water heater, turn OFF, drain water and replace anode. flush W/H too.
REMEMBER DO NOT TURN ON ELECTRIC UNTIL W/H IS FULL OF WATER!
eddie and sandie
3402 Montana 2013
Ford F350 2015
