Jun-11-2013 10:09 AM
Jun-13-2013 04:30 PM
mobilcastle wrote:mr. ed wrote:
One tool that some folks may not consider is a tire valve stem removal tool. It's a good idea to check your valve stems for tightness occasionally because if one loosens you'll have a slow leak and gradual reduction in air pressure. I've had this happen before, thinking it was an object stuck in the tire but it turned out to be a loose valve stem.
I carry the same tool when on my bicycle so when I get a flat I can completely remove the valve and inject "green slime" into the tire to seal the flat. It's a little tool but so handy when needed.
Good tip-i carry one but never think about checking my stems to see if they are tight. I also carry a tire plug kit, however I will start to have my tires patched from the inside like I used to when I go out fulltime.
Jun-13-2013 03:17 AM
Jun-12-2013 03:42 PM
Jun-12-2013 03:23 PM
Jun-12-2013 01:54 PM
korbe wrote:
My tools at home do not come with me while campin'. Those tools you buy at Home Depot would now stay in the rv.
Jun-12-2013 05:19 AM
Jun-12-2013 05:05 AM
Jun-12-2013 02:19 AM
n7bsn wrote:Trackrig wrote:
Put together a seperate tool kit that just stays in the RV or the truck. It's simpler, saves time, and you don't forget to pack or go find something in the garage before you leave.
Bill
What Bill said... the RV tool's don't have to be Snap-On, Harbor Freight can work just fine. I found I didn't have a really LARGE wrench, so I dropped by HF and bought one. Last trip we used it has a hammer too boot.
I carry a fairly complete set of wrenches, screwdrivers, pliers, hammer, wood-saw, mini-hack-saw, box of assorted nuts/bolts/screws, some electrical tools (a free DMM from HF), fuses, light-bulbs, one drill/driver (which also runs the stab-jacks up/down).
Jun-11-2013 07:37 PM
rattleNsmoke wrote:
Carry a credit card and cell phone.
Jun-11-2013 05:49 PM
Jun-11-2013 05:41 PM
Bill
Jun-11-2013 04:41 PM
Jun-11-2013 01:53 PM
