Whats Your Real Weights? Truck and Trailer. The Real Deal
juzplanekrazy
I don’t know if it’s been done before or not but I was thinking about keeping a running list of real truck weights by year and type, and trailer weights by brand, size and what the total combined weight is of each guys rig. I was hoping the info would be a help for guys wondering about what the real weights are for a certain type of truck and to keep track of the more popular brand 5th wheel trailers. Another thing that will come out of it will be to see just how many guys really know what they are towing and if they know what their weight capacities are.
I’m sure it will take some time to compile a list and it will grow as guys add there info but I’m hoping it will help the newer guys in the long run to be directed back over to this thread in the future.
I’ll keep the TV lists to mainly the big 3 and from ¾ ton and up and I’ll try to keep the 5ers in a group by real GVW, length, and then manufacture. Any ideas are welcome as long as it makes things easier. And only real information can be given, so no guessing allowed. Only guys that have scaled there rigs or are totally certain of the weights.
Let’s see if I can keep the format real simple to type down and that will make it simpler for guys to refer back to and to keep track of.
Here we go……
TV - 2006 Dodge Mega Cab 3500 4x4, real scaled weight with full fuel, hitch, DH-DW and misc. gear = 7,500lbs. TV GVWR is 10,200lbs
5ver – KZ New Vision TH 38ft 14,500lbs loaded GVW. GVWR is 18,000lbs
Normal running TV & TH GCW weight= 22,500lbs, TV GCWR is 23,000lbs
Real Wet Pin Weight=2,950lbs
2021 Dodge Ram Longhorn 4x4 Dually
2019 KZ Durango Gold 371
B & W Companion 25K
859 REPLIES 859
Cummins12V98
"Looks like you have 3,900# of stuff in the 5er, are you an anvil sales person??"
I have at least 5k of "Stuff" what does that make me?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
rhagfo
donroe123 wrote:
Newbee hitting the road. Figuring weight is crazy to me. Here are my numbers if someone with more brain power will look at them.
Ram 3500 dually 6.7 diesel scale weight front 5220
rear 3840
with 375res solitude attached front 5320
rear 7640
trailer axles 14,200
total weight 27,220
Trailer GVWR 16,800 Truck GCWR 30,000
Axle GAWR 7,000ea GVWR 14,000
Thanks for any opinions
Well the TV is fine, but the GVWR on that 5er is 16,800# I calculate yours to be 18,100# so about 1,300# over GVWR, and you have your trailer axles maxed out.
Cummins12V98
rear 3840
rear 7640
total weight 27,220
I think you are fine! Just remove a complete clutch assembly from my tool box and I would be at or within SAE Ratings. You have PLENTY of room to grow.
You added weight to your front axle that's good. Your hitch must be forward of axle centerline.
Do you have the AISIN trans?
donroe123
rear 3840
rear 7640
total weight 27,220
GPG52! wrote:
We are fortunate enough to have two 5th wheel trailers
2014 Keystone Cougar 327 RES which we have now parked and use as a summer cottage
and
2005 Keystone Cougar 285 EFS which is easier to tow and park.
2014 Ford F250 Super Duty
Weight at an MTO commercial scale (Ministry of Transportation Ontario)
Truck steering axle (front) 4,431 lbs
Truck rear axle trailer attached 9,480 lbs
Truck and trailer combo 16,799 lbs
Trailer only while attached to truck 7,474 lbs.
Both units were loaded from a return camping trip, two 30lbs propane tanks full, 2/3 potable water in holding tank. Grey and Black tanks empty which is our typical travel configuration
There is NO WAY your rear axle is at 9489 with those trailers... IF so, you are WAY over your RAWR... My 2020 F359 has a RAWar of 7259... my 2915 F350 was 7100
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
GPG52_
and
GPG 🙂
2014 Ford F250, 6.2L, 4.30 Ratio, 6 speed
2014 Cougar (by Keystone) 327 RES
Learjet
Stealth908 wrote:
My 2004 Chevy Kodiak C4500 and 2018 Montana High Country 385BR weighs in at 28,040 lbs. I’d like to post a picture. How do I do that?
drag your picture into this link...then post the link under the picture
It will make sense when you open it.
http://photoposting.is-great.net/?i=1
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
Stealth908
rconkin
After years of camping, I finally weighed my current truck and 5er in my sig.
Truck with full fuel tank.
Steer 5000
Drive 3660
Truck with 5er and full fuel tank
Steer 5000
Drive 6440
Trailer 12180
So I have a pin weight of 2780 (18.5%) and gross trailer of 14960 with 1/2 tank of fresh water. A lot heavier than I thought I was.
Oh, I have run Sailun G rated tires on 5er since I bought it.
2008 Fleetwood Discovery 40X
2007 Hummer H3 toad
"For those that fought for it, Freedom has a flavor that the protected will never know!" Semper Fi
wtbman
TV 2014 Ram 2500: 8,380 lbs - 5,060 front - 3,320 rear (fueled up + me)
TV + 5er: 5,060 front - 5,020 rear (axle GAWR 6,000 front 6,500 rear)
GVW: 10,080 (GVWR of 10,000) leaves me 80 lbs overweight plus wife and kid 😞
Trailer 2006 FR Wildcat: 11,120 lbs total - 9,420 axles - 1,700 pin
Trailer dry rating: 9,500 total - 1,300 pin
GCVW: 19,500 lbs
I am happy to find out I am within axle ratings and GVWR fully loaded but not so much that I'm over GVWR (in my mind I thought it was 10,500 lbs). I don't have any safety concerns about the GVWR but worry about possible issues with the law. I would rather have more truck than I need and be under the numbers but this is what I have to work with. Honestly I wouldn't want tow anything heavier with this 2500. I added airbags to soften the bucking but doing it all over I'd opt for the 3500, DRW if towing anything bigger long distances.
LaundroKing
2005 Ford F250 6.0 extended cab / Hartland Sundance 30'fiver.
Steer axle 4480#
Drive axle 5900#
Tlr axle 7960#
Ready to camp. Half full fresh water. 90gal fuel.
Mark
2005 Ford F250 6.0 PSD BulletProfed
2008 Hartland Sundance 30ft 5er, Flexair pinbox, Center point equalizer.
rhagfo
rbcamping wrote:
rhagfo wrote:
Well we had a bit of a surprise when we weighed this week. :E
Not a Cat Scale, but ODOT road side scal accurate within 50#, scale was about one mile from park we were leaving.
TV 2001 Ram 2500 with Camper Package.
Trailer 2005 Sprinter 293 FWSWS 32'
Unloaded TV with full fuel with most stuff loaded.
Front GAWR 5,200# scaled 4,500#
Rear GAWR 6,084# scaled 3,350#
Loaded TV
Front 4,550#
Rear 5,950#
Total 10,500#
Trailer
Pin 10,500# - 7,850# = 2,650
Axles 10,125
5er total 10,125# + 2,650# = 12,775
Total GCVW 20,625#
This rig tows great does well on hills both up and down.
This is stock 2500 with Camper Package and a full set of Bilstein 5100 shocks.
If your truck has an auto, you might want to check into putting the 3rd gen front brakes on the truck, it's about 35% more brakes over the second gen. You will have to change your wheels and tires, but its a very big improvement and not that expensive. I have a 2000 2nd gen with bigger brakes, 19.5 wheels and tires, Allison auto, bigger drive line and more power, pulls great, towing a 16000 lb camper. I have yet to weight the rig. that's next.
Well the 2001 has a PacBrake turbo mounted that works great down hill never need to use the service brakes.
It is a great TV, but we are looking at going down to one vehicle, SO we needed to get something a little new and bigger.
rbcamping
Loaded TV
Front 4,550#
Rear 5,950#
Total 10,500#
Trailer
Axles 10,125
Total GCVW 20,625#
bpounds
The manuf axle rating includes the rubber, in fact often the rubber is the rating limit. So unless someone downgrades, you will be okay
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
rhagfo
Cummins12V98 wrote:
bpounds wrote:
Looks good to me. You are within the axle ratings, which is what matters.
Yes but ya better have the rubber to carry the load also and he does.
The rubber is very good!
The optional 265/75-16E @ 3,415 ea. for a total of 6,830# capacity on the rear axle. 5er Yokohama LT’s @ 3,042# ea for 12,168# capacity on REAL tires!
