Hospital Coder
rfporzio
Hi All, Getting prepared for full time out on the road. I'm hoping to use my accreditation as a In-patient and Out- Patient certified coder. Can anyone who is currently doing this point me in the right direction. My plan is to settle here on my property in Vermont for the good months, May through October. Then off to a warmer climate.
Thanks in advance for your help.
2012 Tacoma 4WD
2012 Camplite 5.7
9 REPLIES 9
jpmihalk
I work in IT for a large healthcare organization. Almost all of our coders are home based now, with multiple secured methods of accessing the applications needed to do their work. Home coding is the wave of the future in healthcare, pretty much every major healthcare system is now doing similar things to provide access for their home coders.
John & Kerri
2016 Thor Hurricane 35C with our pups MacDuff, Piper and Annabelle
gatorcq
"I believe the prior poster's pint around a hard connection are the patient confidentiality rules around protected health information (PHI) mandated by HIPAA."
VPN is a software application that is installed on the owners computer which is then secure to the company network. ALL mayor corporation and businesses used this. It is highly secured and encrypted
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 2015 Ford F150 XLT
Roadmaster and Air Brake System
1600 Watts, Magnum Inv/Chg&Solar
800 Lithium Battery
DaGirslRV Blog
Belgique
Thanks for this thread. Will be following. DW finished her training and will take the cert exam next month. Goal is to Code from the road.
Hickory, NC
2007 Fleetwood Discovery 40X
rfporzio
thank you all. I am training currently for ICD-10.
2012 Tacoma 4WD
2012 Camplite 5.7
R__Walter
pconroy328 wrote:
I'm not a coder and there could be some obscure requirement that I'm unaware of, but I wanted to add that you don't need a Wired connection to establish a VPN link.
I VPN in to work over wireless (Home, Starbucks...) all of the time. That's kind of the point of VPN - establish a secure channel over any ol' Internet connection.
๐Ÿ™‚
2016 Ram 3500 Aisin SRW LB
2005 Hitchhiker DA 31.5
Fulltimin'
Wally_Walleye
The hospitals in AZ explode in the winter time with all of the snow birds. You might want to contact some of them to see if they hire on temp help in the winter to help with the influx of pts. I worked PRN as an RN in an emergency room from Nov to April. My choice of days and hours. They were glad to get help. All departments were the same. Call and speak to the department head to see if something temp is possible. Good Luck. Also many of the resorts have local hard wired internet available at their sites. There are options available to you. It is good to start the research now.
pconroy328
๐Ÿ™‚
n7bsn
Some friends that "do that from home" have to have a secure hard (wired) connection that can be configured to handle the VPN setup to talk to the hospital system securely.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
Second_Chance
Robert,
Talk to some hospitals around you. Our large community hospital "sent the coders home" a couple of years ago (they're all coding remotely, in other words). Have you trained and certified on ICD-10? It's coming 10/01/2015.
Rob
U.S. Army retired
2020 Solitude 310GK-R
MORryde IS, disc brakes, solar, DP windows
(Previously in a Reflection 337RLS)
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
