50 amp surge protectors
MarkTwain
Looking for a surge protector, any recommendations for the best.
50 REPLIES 50
Mile_High
If you want to research, Surge Guard by Southwire is the competitor to Progressive Industries, and in my opinion, Surge Guard has much more depth into surge suppression than Progressive Industries. The Surge Guard Model 40240 is the equivalent to the PI EMS-HW50C. I previously installed a Progessive Industries EMS-LCHW50 in a fifth wheel and I was not overly impressed so the next time I looked around.
You might also check your MH - many already have some sort of surge associated with the transfer switch. Mine had a Surge Guard Model 41260 which is considered "light" surge or "limited features". I replaced it with a full surge/transfer switch model Model 40350-RVC which gives me all the best surge features including the remote readout inside the coach.
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
rhagfo
AllegroD wrote:
https://www.rvupgradestore.com/rv-surge-protection-comparison-guide-a/279.htm
Progressive Industries EMS-LCHW50 hardwired. it is on the bottom page, with the remote display no need to go out in the weather.
Interesting only two NO entries are weather proof and lockable, nether matter for a hardwired unit.
Here is a very good price on the unit.Best Converter
westom
MarkTwain wrote:
Thanks for the info. What 50 portable unit surge protector would recommend. I would like a protector that shows the lights clearly and that are easy to read.
Where is the list of anomalies that are a concern? So many different devices address a long list of unrelated items - all called a surge.
For example, a blackout is hyped as a surge. Do you need protection from that? Low voltage is a surge. Is that a concern? Reverse polarity - a surge.
The thing hyped as a surge to homeowners is typically completely different from what concerns most at a campground.
So greater concerns are reverse polarity, disconnecting from a voltage so low as to be harmful to motorized appliances, disconnecting from a high voltage (ie floating neutral), and disconnecting if the safety ground does not exist.
Whereas homes are more concerned with surges such as lightning, then many campground protectors do not address that surge. Home also do not worry about low voltage. Another anomaly not addressed by a protector for homes that is a concern in campgrounds.
Long before asking for a solution, first identify the solution. The Progressive products are popular, in part, because those protectors are good at addressing type of surges more commonly found in campgrounds.
One anomaly that protectors cannot detect is an open earth ground at the pole.
edatlanta
I have had the EMC-PT50C in service ever since I started full timing in 2010. After the first time the campground I was in had some major electrical issues and campers around me had burned up "stuff" and I was 100% OK, I got a bit paranoid about electrical issues. So what did I do? I bought a second PT50C as a spare. When the primary one fails I never have to plug in without one while I'm sending the failed one back for service. In the past 8+ years I have had many saves (two on my home base site) and actually had 2 of the PT50C's destroyed beyond repair and they were both replaced by PT50X's one of which I am using right now and I still have a brand new one still in the box in reserve.
I will absolutely never plug in anywhere without my PT50X inline.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
wa8yxm
bob213 wrote:
Don't be lured by a cheap price or good deal on a surge protector. You need more than a surge protector. Look at the EMS unit everyone above has suggested, either hard wired or portable. You will pay a lot more but you will be fully protected. Progressive Industries EMS is what you should look at first.
I will second that. There are many "Surge Protectors" that are nothing mroe than spike supressors.. GOOD as far as they go but no over/under voltage/frequency protection. THe ones cited above all provide "Broad Spectrum" (Medical term) Protection.
A hughes Autoformer provides limited LOW VOLTAGE protection and spike spuression (MOV's) only it does not protect you from open neutral or 240 volt 30 amp outlets like the Unitrs above do.
How to hook up
Park----Hughes---PI---RV
AllegroD
kdk
Installed a Progressive Industries EMS-LCHW50 hardwired unit in 2006. Saved me several times. Earlier this summer got connected to a bad power supply and it protected my motor home but burned out the protector. Corrected the power pole and bypassed the unit after reassuring every thing was ok. Called Progressive Industries and told them it was my fault that it was miss wired, they said under warranty we will send you a new no charge. mind you it was 12 years old, can't beat service like that. we were on the road and when we got home 3 days later a new one was sitting on my porch. I also like the remote where I can monitor voltage and amperage inside.
Did I say warranteed for life, other manufactorers don't offer this.
Blessings;Keith
06 Holiday Rambler Ambassador
2016 Ford Explorer twin turbo
et2
mike brez wrote:
I have been using this PI with three rvs now
Yep, good unit. Our's is on it's 4th rig. Does the same thing as a hard wired ... But easily portable to future rigs. Takes a licking and keeps on ticking. And it's found faulty campground wiring.
Edd505
X1 same one
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
wa8yxm
dalenoel wrote:
Progressive Industries EMS-LCHW50 hardwired. Nothing better. Product Info.
I have not updated my research lately but having looked at this one. Yes. I'll second that.
HW in the model number means it is hard wired. so you never forget it.
It also means it is outta sight outta mind when Mr. Sticky Fingers walks past so it does not "Grow legs" and walk off.
In the old days I'd have recommended the HW-50C but this appears to be an update to that same produce.. Same level of protection.
I WANT ONE.
rhagfo
X4 or X5
Love the hardwired unit with remote display!!
AikenRacer
Progressive is great. I had one for years and it failed. They replaced it with a new unit free....can't beat that!
2012 Tuscany 42RQ tag
2005 Silverado 2500 w/ piggy back golf cart
pianotuna
Nomad III
Nomad III
Consider a Hughes Autoformer. It will fix low voltage in a lot of cases, and offers the same level of surge protection and the other features.
Regards, Don
3_dog_nights
Had problem with my Progressive unit, notified them and they were all over themselves getting me a replacement. They make a great product and stand behind it. Kinda unusual nowadays..........
Bob & Lynn
2 Chihuahua's, Ella, Gracie
was-2013 Open Range 424RLS,06' Chevy 3500, dually, Duramax/Allison
also was - 2015 Winnebago Adventurer 37F, towing 2003 Jeep Wrangler
now - 2021 NoBo 19.5, 2019 Honda Ridgeline RTL (Talk about downsizing!)
bob213
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
