โOct-19-2018 02:24 PM
โOct-20-2018 10:59 AM
โOct-20-2018 10:05 AM
โOct-20-2018 08:44 AM
โOct-20-2018 08:20 AM
โOct-20-2018 06:48 AM
et2 wrote:Mondooker wrote:
You guys are correct, air brakes do not turn on and off, they are constantly on with the engine start. Most diesel pushers have a gauge or trouble lights on the dash showing that brakes and airbags are fully aired up.
As for the slowdown you've noticed its your exhaust break or Jake brake that is slowing you down. You should see a three position switch on the dash allowing you to set it to High (maximum of breaking), Low and off.
Most folks leave the exhaust brake on at all times EXCEPT in icy or wet conditions. Especially true if your coach has a tag axle.
Not sure what a tag axle benefit the exhaust brake gives vs no tag. The brakes on a tag axle are way more capable of slowing down vs no tag. Actually the exhaust brake on our tag is not as effective as the non tag we had. Probably because it's a lot more weight. I find I use the brakes more.
โOct-20-2018 04:15 AM
โOct-19-2018 10:47 PM
Mondooker wrote:Just to be more accurate, it depends on the coach as to the 3 position switch. Some have Off/ON, others have LOW/HIGH, while others have LOW/MED/HIGH.
โOct-19-2018 07:37 PM
โOct-19-2018 05:59 PM
โOct-19-2018 05:54 PM
Just to be clear, both Pac and Jacobs make both exhaust and engine brakes, with only the engine brake having a switch selection of braking strengths. These are only found on the higher end coaches and are superior in braking performance. Granted that Jake has the market on engine brakes and seems that Pac has the market on the exhaust type.
โOct-19-2018 05:22 PM
โOct-19-2018 05:13 PM
flyboykuao wrote:
Hello, we recently purchased a Fleetwood diesel pusher. We have been on 3 short trips with it. It is equipped with air brakes - when switched on the RV will slow when my foot is off the pedal. I read up, and now understand, how they work. What I am not clear on is WHEN to use them. I assume one scenario is when on a steep downgrade. What about using them during normal travel as a way to save the brakes?
I am interested in your recommendations. Thanks in advance.
โOct-19-2018 04:35 PM
โOct-19-2018 04:25 PM
