Although CCC is no longer used, here is how it was defined by RVIA in 2000.
(Other definitions are given for clarity.)
- GVWR: Gross Vehicle Weight Rating
- UVW: Unloaded Vehicle Weight (1996 RVIA Definition)
Unloaded Vehicle Weight (UVW) is the weight of a vehicle as manufactured at the factory. It includes full engine and generator fuel tanks and fluids, if applicable. It does not include cargo, water, propane, or dealer-installed accessories. Be aware that some manufacturers weigh each unit to determine UVW, while others provide only the average or estimated weight for each model.
Note: Some dealers include the weight of all factory installed options; other include the weight of commonly ordered factory installed options.
- SCWR:
Sleeping Capacity Weight Rating (2000 RVIA Definition)
The manufacturers designated number of sleeping positions multiplied by 154 pounds (70 kilograms)
- CCC:
Cargo Carrying Capacity (2000 RVIA Definition)
Equal to GVWR minus each of the following: UVW, full fresh potable water weight (including water heater), full LP gas weight and SCWR.
- NCC:
Net Carrying Capacity
Equal to GVWR - UVW
The federal government (NHTSA) developed its own standard, Occupant and Cargo Carrying Capacity or OCCC, which is a very different number. CCC is in addition to water and passengers; water and passengers are part of the OCCC number.
A label is required (by the Feds) to be affixed to the coach with the following information:
"The Combined weight of occupants and cargo should never exceed
xxx lbs or xxx Kgms
Seat belt equipped seating is X
CAUTION
A full load of water equals xxx Lbs or XXX Kgms of cargo 1 gal =8.3lbs and the tongue
weight of a towed trailer counts as cargo."
The label should be black type on a yellow background.
In our coach the label is affixed to the wall just to the left of the driver and is beside the VIN number label.
Note: for trailers, the NHSTA defined a CCC, different from that defined by RVIA. It is the same as OCCC except the number does not include the weight of passengers.
Tom
2015 Meridian 36M
2006 CR-V toad
3 golden retrievers (Breeze, Jinks, Razz)
1 border collie (Boogie)
