โAug-27-2016 09:56 AM
โAug-28-2016 02:26 PM
โAug-28-2016 12:19 PM
Jagtech wrote:
All engines have an optimal rpm range, and MOST manufacturers will take that into consideration when building a chassis. That's what you want to see at cruising speed if you are considering a gear change.
โAug-28-2016 10:33 AM
Jagtech wrote:
Lower engine speed equals larger throttle opening, which effectively negates any fuel savings.
โAug-28-2016 10:15 AM
Dstrahm wrote:
Has anyone changed the differential gears in their MH to a different ratio? Our 1999 Brave is geared way too low for how we use it and my thought was that I'd get better mileage with a higher ratio. Now at highway speeds the engine is running around 2000 RPM and it has enough low end torque to pull stumps easily. I'd gladly trade a slower acceleration off the light for better gas mileage and a quieter running engine. The axle is a Dana model, 80 I believe.
Thanks!
โAug-28-2016 08:20 AM
Dstrahm wrote:
Sam Spade, it's a bit disappointing to see a Senior Member disrespecting another member, a recent member at that, with such comments.
Let's all remember to keep it positive and respectful. If I misinterpreted your response, please accept my apologies.
โAug-28-2016 08:04 AM
SoCalDesertRider wrote:
Whatever the axle ratio and tire size are, the engine is cruising at 2000 rpm in high gear at normal highway speeds and that is just fine for a gas engine. The coach is geared appropriately. There's no reason to raise (numerically lower) the gear ratio or go to taller tires (which accomplishes the same).
โAug-28-2016 08:02 AM
โAug-28-2016 07:55 AM
โAug-28-2016 05:26 AM
โAug-27-2016 08:06 PM
โAug-27-2016 07:26 PM
โAug-27-2016 06:50 PM
โAug-27-2016 06:34 PM
โAug-27-2016 06:00 PM
It is proven that operating at low rpm with foot deep into the pedal produces lower fuel economy, than operating at higher rpm with less thottle, when the engine is under load.
