Changing oil on a diesel cummins generator
rbanuchi
Does anyone know a resource to learn how to change the generator oil in my cummins generator 7500? I would like to learn to do by myself and the one thing I was told to make sure that I use the exact amount of oil to replace what is removed. Thanks for any information
11 REPLIES 11
msmith1199
Clicky for Video
This is a good video that answers your questions.
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
jtfcons
I know on my set-up it's neccessary to undo the exhaust pipe hanger for the generator and swing the pipe out of the way to get the hinged door all the way open. I have also found it better to remove the two screws that hold the door to the hinge and get that totally out of the way. Gives better access.
John & Sharon, 2 Daughters, 2 Sons-in-law, 5 GK, 1GGK
Rat Terriers (Twiggy, Annie)
1997 HR Imp., 38CDS, 1 Slide
325 Cummins C8.3Mech., MD3060, EBw/Coast.Sw.,
Toad-2003 GMC Envoy 4X4, Excallibar TB, Pressure Pro TPMS, Henderson Mot. Ctrl. Units
JR45
This may help
http://www.youtube.com/watch?v=CxqkHAAH818
JR
2006 Country Coach Inspire 360 40ft Genoa Designer Series Cat C9 Samsung 197 RR
Aluminum Radiator was recently replaced with a STEEL & COPPER Bolt Together Radiator w/ updated rubber mountings
SilverLeaf VMS 330
Toad--2011 Ford Edge Sport, Air Force One
:C
Raymon
rbanuchi wrote:
Everyone , thanks so much for your input. It's truly appreciated I have a stupid question though. When refilling the oil, does it get filled directly into the spout on top There are two spouts one for oil and a second one slips my mind at the moment. Thank you again !
You add the oil into the dipstick tube. The other tube is for the coolant.
Ray
rbanuchi
YC_1
The filter can be a bear to remove so buy a new filter and a tool that goes over then end of the filter that you can run a 3/8 inch extension to and use a ratchet. Do not overtighten the new one. Just snug and then about 1/4 turn.
H/R Endeavor 2008
Ford F150 toad >Full Timers
Certified Senior Electronic Technician, Telecommunications Engineer, Telecommunications repair Service Center Owner, Original owner HR 2008
Snomas
I took my oil filter to Napa auto parts and they gave me a matched filter to replace the original Onan filter. I use Shell Rotella 15-40 in the engine and the Onan Gen set. I put in 2 1/2 qts and run generator several minutes and then check and top off. Don't over fill!! The manual says to replace the coolant plug every 2 years and you can buy @ any cummins dealer.
2006 WINNEBAGO ASPECT 29H Ford E450 Super Duty
2018 F150 Lariat Crew Cab, Coyote 5.0 L RWD
Raymon
JackMS wrote:
Remember to wipe a little clean oil on the new filter gasket.
Also make sure the old gasket came of with the old filter. My Onan owner's manual states the the new filter may be a little smaller than the original filter; my replacement filter was slightly smaller than the original filter.
Ray
JackMS
2005 Holiday Rambler Neptune 34pdd, Cummins ISB 300, Allison 2500MH, Onan 8.0QD
Prior Toad-2001 Chevy 2500 CC 4WD
Toad-2012 Honda CRV, Blue Ox Aventa II
barnaclebill
The access door to the oil filter is hinged, just push the 2 release tabs with your fingers to open. The drain plug is labeled "oil drain" It is easy to do, go for it! I hope this helps, Bill
2009 Monaco Camelot 42PDQ
425 Cummins
Chevy Equinox or Tracker
Blue Ox towing
smlranger
The Onan 7500KW genset uses exactly 3 quarts of oil. Just remove the drain plug (threaded plug) on the bottom of the genset, drain the oil. Remove the oil filter (inside the little access door on the bottom of the genset), and replace with a new filter. Fill with 3 qts of oil.
I always use the same oil I use in the coach diesel engine, 15W40.
2019 Grand Design Solitude 384GK 5th wheel. Glen Allen, VA
