clorox bleach in diesel
hr
I put 1 cup of clorox bleach in diesel tank (90gal) by mistake!The fuel hole is right next to the water fill,What should I do?
HR
91 REPLIES 91
JohnnyT
Ok it time to put this one to bed... Nothing constructive going on...
Topic closed
JohnnyT Moderator
2004 40DS02 Travel Supreme ISL 400
Jeep Grand Cherokee, Ford F150
M&G Brake & Break Away
Blue Ox Aventa LX Tow bar
wildmanbaker
Sully2 wrote:
00 BUCK wrote:
Mushroom wrote:
Guys, that's 1 cup in how much fuel?
Bleach is an oxidizer - I'm surprised it hasn't caught fire
You cant be serious!
Yes... Will it ever stop.
Wildmanbaker
Horsedoc
Some things you just can't fix! :S
horsedoc
2008 Damon Essence
2013 Jeep Sahara Unlimited
Blue Ox tow
Sully2
presently.....Coachless!...
2002 Jeep Liberty
2016 Ford Escape
00_BUCK
2011 Newmar - VENTANA -- with COMFORT DRIVE :B
2011 Jeep Wrangler Unlimited Sahara
Blue Ox Aventa LX Tow bar w/ Roadmaster adapters
AirForce One brake system
Life Member GOOD SAM Club
FMCA Member
If your not the lead dog
the view never changes
Sully2
hooligan wrote:
HR: Good response, pays to not take a chance, if just for the peace of mind....
FWIW
Sully may not be off the mark, 1 cup of bleach at 6% solution is less than a 1/2 ounce of Chlorine in 90 gallons of fuel. (11,520 ounces)
It certainly isn't super chlorinated.... I'd look to the water separator. And the nice part is we don't have to prove it,-- opinions you know!!! Everybody's got one..
And as Bartels and James used to say.....We thank you for your suppport!!
2002 Jeep Liberty
2016 Ford Escape
hooligan
FWIW
Hooligan U.S. Coast Guard Ret.
2016 THOR Siesta Sprinter 24ST Diesel
2008 SUZUKI Grand Vitara TOAD
1 Pug "Lily", 1 Newfoundland, "George"
1972 MotoGuzzi Eldorado
phranc
HR ,, nice fix and recovery. I will put your solution in my
memory bank for when I might need a cool headed repair !!
2008 Diesel Bounder 38V
johnwalkerpa1
Interesting thread!
I was just wondering...has anyone personally known of a case where someone got beach in a fuel tank and it caused damage? Or is it all speculation? And, of course, I am talking about a small amount, not someone dumping in 20-30 gallons, etc ๐Ÿ™‚
I am not doubting anyone one way or the other....in fact it never even crossed my mind before reading this thread.....I am just curious if anyone has first-hand knowledge of this happening or if most are repeating something heard second-hand.
sundance_8
Horsedoc wrote:
One good thing - no algae growing in the fuel? :h
When I first saw this thread I thought this was why it happened.
www.threedogsandus.com
33_Ford
Try this in a clear glass container. Put some fuel in the container. Add small amount of chlorine and see where it goes. If it settles to the bottom add some water. They should combine and dilute the chlorine. If this happens as expected, I would add water to my fuel tank,wait awhile and then drain this mixture from the bottom of the tank either from a drain plug or using a siphon or small pump. Talk about your two cents worth!
barnaclebill
hr, glad everything is OK, I would have been worried also and took the route of better safe than sorry and drained it as you did! Now it is time to add the fabric softener ๐Ÿ™‚
2009 Monaco Camelot 42PDQ
425 Cummins
Chevy Equinox or Tracker
Blue Ox towing
Jarlaxle
Sully2 wrote:
Household bleach s only about a 6% solution...so what you basically did was dump a pint of WATER in your fuel.....your water separator will remove it
If you are so sure of that, please dump a pint of bleach in YOUR fuel tank and prove it!
John and Elizabeth (Liz), with Briza the size XL tabby
St. Bernard Marm, cats Vierna and Maya...RIP. ๐Ÿ˜ž
Current rig:
1992 International Genesis school bus conversion
hr
Will this is what I did!
I pump out the tank and then I leveled the motor home and drained the sump dry, I then went back to the fuel water separator and blew the line out that went back to the tank, the drain plug was still out. I changed the fuel filter and the water separator filter, I put a 32oz bottle of power service in the tank and started to put fresh fuel back in until I had 20gal in it I started it and drove to the fuel station and filed up then I drove about 6 or 7 miles and no sign of any thing wrong. Since then I have not been able to drive it but I did start it 3 different times and let it run for a hour still seems to be all right.The 300 plus in fuel I gave to a friend with a oil furnace I thought the cost of the fuel and filters was better than a fuel pump or something else.I hope I am right.
HR
