Aug-14-2017 05:29 AM
Aug-18-2017 05:57 AM
Aug-17-2017 12:04 PM
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
Aug-17-2017 10:12 AM
Aug-16-2017 04:37 PM
Aug-16-2017 04:18 PM
Aug-16-2017 07:15 AM
Aug-15-2017 08:53 AM
wa8yxm wrote:
I have the Rino Wrench. I used to have another but lost it. The old one worked well but the new Rino one.. Not so pleased.
One option is a Tetford Sentenal hose.. Google it and you will see what is so good about this puppy.
Now what I do.. For the sewer outlet cap (You put on when moving) I use a block of wood and the heal of my nand more often than not to lock/unlock it
For the hose. Well I have enclosed plubming on my class A. NOTHING hangs below the RV. so I have a 5" Extension with a 45 Degree elbow (both clear plastic) Not only locked to it but glued on so it won't come off (Goop) This hooks to the RV.. My Tethford Smart Hose or other sewer hose (Depending on length needed) hooks to it.. Hooking up I first hook the hose to the adapters then insert the extension up through the portal and lock it on, it locks on easily due to the elbow.. Removal is the reverse.. First remove extrension then unlatch hose
The "Sentenal" has a long collar on the female end. makes it way easier to grip.
I have one of those too. not, yet, used.
Aug-15-2017 07:45 AM
Goldencrazy wrote:
Great ideas. Today i purchased an adjustable oil filter pliers for 10 bucks at Harbor Freight. Looks exactly like what i need. I let my wet bay get messy and cluttered so got rid of my old hose and purchased a rhino and extension. Cleaned it all. Discovered my outlet was rattling on the ridge that supports it so placed foam under. Placed all my sewer related stuff in a rubbermaid container and the fresh water hoses in another with the extension cords. Much neater. I am trying to keep better storage without chance for rattles and more orderly. Will spray the connectors with silicone. Thanks all for the ideas and i will let you know in about 4 months how i am doing.
Aug-15-2017 06:58 AM
Aug-15-2017 04:16 AM
hostage wrote:hipower wrote:hostage wrote:hipower wrote:
I understand your problem with hand strength and suspect that many of us will encounter the same thing at some point.
The wrench you suggested is nothing sophisticated and simply a plastic spanner wrench. I found them at several places for $5.75 and up. For that kind of money I'd buy two. One to use and one to use as a pattern for a machinist to make me one out of aluminum if I was afraid of breaking the first one. If I was going to have one made I'd probably extend the handle a little depending on my space available when using it. Not because I think the extra leverage would be needed, just because it may be and it wouldn't add to the cost significantly.
The bad side of that thinking is you would probably have $100 invested in a wrench that you could replace 15-20 times for the same money in the plastic ones.
rhino come as a pair @12$ left and right as in on and off
The logic of that escapes me. On or off would be simply controlled by the wrench placement on the fitting wouldn't it?
beats the hell outta me? I just saw it was two wrenches for 12$ and thought with the grooves and the way they grip there may be one for install and one removal
Aug-14-2017 09:03 PM
Aug-14-2017 04:27 PM
Aug-14-2017 04:00 PM
Aug-14-2017 03:08 PM
