DP Brake Job Cost?
prstlk
07 HR Ambassador, 40k miles.
Starting get some squeel when stopping normally, and a shudder when stopping hard. What does a brake job run for a DP? Any national chains you would suggest?
Thanks in advance.
JW
2007 Keystone Challenger 5th wheel, Ford F350 Super Duty 6.7L Diesel, Short Bed, 2 dogs and the cat and rolling down the road full time since May 2014
20 REPLIES 20
Passin_Thru
Also, if a brake is out of adjustment it will squeal. Very common on big trucks. I'd get a 9/16 box end and a ballpeen hammer, get under there and tap the boxend of your wrench onto the nut, this will collapse the lockring and allow you to adjust the brake. Turn it unitl its tight and back it off 1/4 turn. This will allow it to rub but won't hurt it. Then back off until the lockring pops back up. It takes 3 minutes to do a single axle and Freightliner will charge you $75.00. Inspect the pad and see what the thickness is. If you don't know what it should be look it up on the internet.
https://www.bing.com/videos/search?q=adjusting+slack+adjusters&FORM=VIRE2#v
mpierce
On my Peterbilt, with brakes the same, I had shoes, cams, bushings, etc replaced for $2200. Essentially everything except the drums. I would take it to a HD truck or trailer shop, and have them take a look. They can make sure everything is operating properly, and give you advice.
The brakes are the same as on 98% of the semis and trailers on the road.
Bigdog
Right after I bought my rig, I had a rear axle seal leak and they replaced the shoes on the one side and I asked if they needed to be replaced on the other to match them up and was told that I had over 80% on them and the brakes would adjust them selves. 81K on the 40' Tradewinds LTC at the time..
GO COUGARS
2001 Tradewinds 7390 LTC
330 Cat Turbo Freightliner Chassis
2011 Jeep Liberty(toad)
'88 Mustang 5 Spd 5.0L GT convertible (not Toad)
mtrumpet
Just returned from a trip to Spartan Factory Service. Brake inspection said I still have at least 65% left on my brakes. My current mileage is 97,750 miles. No way that you should need a brake job at 40,000 miles. If so, there is a serious problem with the brake system and components.
Mark & Cherie
2002 Newmar Dutch Star DP 3872, Cummins 350 ISC, Spartan Chassis
Preacher_Man
Just spent right at $1150 for mine. New shoes and drums all the way around. We had about 270K miles on the coach when we had them done. They probably should have been done 20K miles earlier.
Mark Walter
J-Angel Productions
Web and Media Company
2004 Sportscoach LE 376 DS
Cat 3126E, Allison 3000
jwmII
Most responders here are pointing to glazing and slack adjuster adjustment. From your description of the problem I agree with the diagnosis on the possibility of glazing and doing a proper adjustment of the brakes. There is no way at your mileage that you need new brake linings unless there has been severe abuse of the brakes.
jwmII
Gjac
Executive wrote:
Depends on what's wrong with them. I had to have mine replaced last year at a cost of $10,000. They had gotten wet when we were stuck in a flooded campground and the calipers had rusted. The calipers were $3600 EACH! Insurance paid for almost all of it...Dennis
Were just two of your calipers replaced? Of the $10,000 how much was for labor?
Cbones
As many other posters have said, it is highly unlikely that you need a brake job. What most likely has happened is the brakes have gotten glazed over. The easiest way to fix that is turn off the exhaust brake and use the brakes like they were meant to be used. You definitely are not going to wear them out. Most people's problems are caused by too little use. A lot of folks will use the exhaust break almost 100% of the time, and then just touch the brakes for a few seconds to finish the last 20 to 0 stop. That is not enough time to drive all the moisture out of the pads. They will then get glazed over and make all sorts of noise. Use them like they were meant to be used for a couple hundred miles and you'll see that will fix 99% of your issues .
JetAonly
Last price I was quoted was $400 a wheel. That said, unless you have disk brakes, they are likely glazed and not properly adjusted. Do you do a daily air system check? That check, among other things, includes a portion that should allow your automatic slack adjusters an opportunity to adjust.
2000 Monaco Dynasty
ISC350
sdianel_-acct_c
We have used several Cummins Coach Care locations throughout the US and have been very satisfied with the service. These Coach Care locations specialize in RV's. There is one in Spokane. Join the Cummins Power Club and save 10%.
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
Executive45
NeverHome2
With a couple of million miles as an over the road truck owner, I don't think a DP would ever need new brakes. They just don't get used hard enough to warrant replacement. Inspect for damage from foreign objects and check your slack adjusters free play. Automatic slacks have been mandatory since back in the '90's. Happy Motoring.
Lovin' Life!!!!
2005 HR Endeavor
Mine has 104,000 on it and just had the brakes checked....they said it would probably go another 100K------
blangen
A couple of weeks ago, I was in Elkhart, Indiana and it rained every day I was there. Pulling out, I noticed minor squeek and shuddering when backing (exactly as you describe). After getting out of there and and a couple hundred miles down the road, no squeeks or shuddering. And it just so happens that I'm headed to Gaffney for my 45,000 service which includes a bunch of brake stuff. My suggestion to you is, if you've been sitting still in humid weather, drive it. And it's also quite possible that your 45,000 service will address anything other than glazing.
PS: I'm not a mechanic but I did watch a mechanic fix a whatchamacallit on TV last night. ๐Ÿ™‚ Bottom line... I don't think you need a "brake job" on a 2007 DP.
