Dual Pane Windows 2007/08 Fleetwood & Winnebago
GeeJay
We are considering replacing our Safari Trek with a 36-38 ft Class A Gas.
Our preliminary Internet research as well as recommendations from this forum has determined that the following coaches may meet our requirements. preferences and budget.
2007/2008 Fleetwood Pace Arrow or Southwind
or
2007/2008 Winnebago Adventurer or Voyage and Itasca Suncruiser or Sunrise
As Canadians we use our coach in cold weather and appreciate the reduction in window condensation Dual Pane Windows provide.
Having reviewed the downloaded brochures for all these models we could not find any reference to Dual Pane Windows either as standard or an option, although we have have been informed they were standard on the Winnebagos & Itascas
Can anyone confirm if Dual Pane Windows were available in any of these these models?
GeeJay & ElleJay w/"Camper"(cat)
Coaldale, AB (May-Oct) & Mission, TX (Nov-Apr)
2005 Safari Trek 28RB2 Class A
Ready Brute Elite Towbar w/Integral Surge Brake
2014 Fiat 500c Abarth Cabrio
"If you have to run your A/C or Furnace - you're in the wrong place!""
12 REPLIES 12
chuckftboy
Pace Arrow was a very high end gas coach and duel pane windows were never an option because duel pane was standard equipment as was satellite antenna, residential fixtures and many more things are usually options on other gas coaches. I owned a 09' 36D and it was exceptional.
2019 Horizon 42Q Maxum Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
rv4jimnme
Hi there,
We owned a 36 foot Pace Arrow for 9 years we had the windows fog up. We put up with the driver and passenger one as long as we could. We replaced the driver's at a cost of $500.00:E then we found a guy who takes them apart cleans them and reseals them for $40.00 each on the passenger side because that had two panes. The dinette and other windows were not too bad but they should have been done maybe at some point? We loved the coach but we have sold it. So just saying check on repair of those dual panes before you spend a ton to replace them.
RLS7201
Dual pane windows are standard equipment on Fleetwood class A motorhomes.
Richard
95Bounder dual pane windows.
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
rr2254545
I owned a 2008 Voyage with duel pane windows - we camped in it for two winters and never had a problem keeping it warm in freezing temps with the propane furnace running and we never had any water freeze in our tanks
2012 Winnebago Journey 36M Cummins 360
2014 Jeep Cherokee
492 Campgrounds,107K miles driven in our Winnebago motor homes and 2360 nights camping since we retired in July 2009, 41 National Parks
cbeierl
Btw, if you have the Winnebago/Itasca Serial Number (not the VIN) of the coach you can go here: http://catalog.winnebagoind.com/menu/Parts.htm and click on Service Parts List on the left-hand side of the page to get a complete, as-built parts list for that particular coach.
Chris Beierl
2005 Winnebago Vectra 36RD
J-Rooster
I have dual pane windows in my 2004 Adventurer they came as standard equipment when I bought the coach new! The Adventurer is Winnebagos top of the line gas coach and there is no skimping of equipment on this model. The Adventurer is also a very well insulated coach and performs very well in the cold! The coldest weather my coach has been in was 9* and it handled it with no problems. Good Luck in your search!
happy-2
I have a 2006 SouthWind 37 c WITH Dual pain windows, I do have 3 windows that need to be resealed some day .when I get time Ill have it done.but not now. LOVE my fleetwood.
GeeJay
cbeierl wrote:
The 2007 Adventurer Brochure lists Window (Passenger) full-slider w/screen, dual-glazed/thermo-insulated as standard. So does the 2007 Suncruiser Brochure.
The 2007 Voyage Brochure lists Windows dual-glazed/thermo-insulated as part of the optional Grand Package. The 2007 Sunrise Brochure doesn't actually list them in the optional Grand Package, but I suspect that just an inadvertent omission, since I would expect the Itasca model to match the Winnebago one.
I presume the 2008's would be similar, but I didn't check the brochures.
Thanks, I had missed that because I was looking in the Exterior or construction specs but it is listed under CAB AREA & DRIVER CONVENIENCES in the spec and now found. Also stated in paragraph on page 2 under Your Home On the Road.
Lesson learned: Read Everything
Trackrig
Call Fleetwood cust serv tomorrow at 800/322-8216.
Our 2005 Fleetwood Excursion 39S has the dual pane windows, but that's a different model than your'e looking at.
Bill
timmac
2008 Bounder 32W with dual pane, I think its standard on all Bounders.
cbeierl
Chris Beierl
supercub
I had a 2007 Southwind 32V and it had dual pane windows.
