Aug-09-2015 09:20 AM
Aug-11-2015 05:10 AM
mgirardo wrote:ljr wrote:
I'll take your word for it but I've been using it for years and haven't noticed anything like that.
I used a CO2 tank for filling my tires after off-roading. The tires definitely lost air more frequently when filled with CO2. That was Bias Ply and Radial tires. However, being able to fill a 33" tire from 12 PSI to 35 PSI in under a minute was very nice. I built the same 20lb system with a variable regulator and PowerTank's 3000 PSI burst coil hose for just about $150, then another $25 for the tank cert and fill-up.
-Michael
Aug-10-2015 05:32 PM
Aug-10-2015 04:30 PM
Aug-10-2015 03:54 PM
Snowman9000 wrote:NWboondocker wrote:
I carry this fairly compact 1.5gal compressor. To me if you have the space it's worth having a small tank sufficient to fill a bike/MC tire without having to plug it in and maybe start the generator. Also nice having regulated compressed air available to blow off something dirty, winterize, run air tools, etc., on the road or at home.
Can that little thing winterize, and run air tools? I am sure it can run a stapler, brad gun, etc. What else? I have a tiny tank model too but I have not tried to winterize with it. I didn't think there would be enough air volume to finish the job. It's still sort of big for my storage capacity, but I do think about taking it along. If it can winterize, that's a plus.
Aug-10-2015 02:11 PM
Aug-10-2015 11:34 AM
Aug-10-2015 10:16 AM
Aug-10-2015 09:46 AM
IAMICHABOD wrote:
I found that those combo units are mostly a joke,and the only way around the clip on chuck is to replace the hose with one like this
If you want a a unit that will pass the "jump start the car test" get one of These
Aug-10-2015 08:58 AM
Aug-10-2015 07:50 AM
Aug-10-2015 06:02 AM
pnichols wrote:
Does your RV have an onboard built-in generator?
If so, just buy a tankless 120V AC compressor from a hardware store to pack along. Just start up the RV's generator and plug it in whenever you want to use it.
That's what we do. Our 120V AC tankless air compressor can inflate up to a maximum of 120 psi pressures, and can run continuosly to inflate any size tire.
A simple and reasonably inexpensive solution.
Aug-10-2015 04:42 AM
Aug-09-2015 10:00 PM
Aug-09-2015 06:41 PM
