Engine fan
mrwrenchman
I have a 2006 Monaco with a 8.8L 400HP Cummins side radiator . Recently I noticed the engine fan is running full speed all the time . I know the fan is driven hydraulically and I think it thermostatically controlled . Is there a thermo. control valve somewhere that is possibly stuck in the wide open position , or some other condition .Any Ideas ? Thanks Don
11 REPLIES 11
mrwrenchman
Thanks guys , they don't make things easy do they . Don
dons2346
Couple of things could be wrong, start with the cheap stuff first.
Find the fan controller and take apart all the connectors on it and clean them with a contact cleaner. If that doesn't work then check all the sensors connected with it such as water temp, intake air temp. If you have the air conditioner on, it will also cause the fan to operate at a high RPM. It will do the same in vent mode also. Your controller could be activated by the ECM also.
A Sauer Danfoss controller can be had fromFluid Bernstein(sp) for about $500. You will need the actual part# because they come programed for your application..Wax valves also go bad but I don't know anything about them. You can get a replacement wax valve from Source Engineering but it is not a direct replacement.
Waco_Kid
I had the same issue, if you have a sauer danfoss fan drive control, it probably failed. There around $900. I replaced mine four years ago and it failed again, this time I replaced it with THIS. and it works great. Bruce
  • Bruce & Sandy
  • 07 Scepter 42PDQ SOLD
  • 2018 Coachmen Leprechaun 26DS Chevy
JR45
Fan controller
http://sourcerv.com/conversion
JR
2006 Country Coach Inspire 360 40ft Genoa Designer Series Cat C9 Samsung 197 RR
Aluminum Radiator was recently replaced with a STEEL & COPPER Bolt Together Radiator w/ updated rubber mountings
SilverLeaf VMS 330
Toad--2011 Ford Edge Sport, Air Force One
:C
MPond
We had the same problem with our ISL 400, and it ended up being the hydraulic fan controller. I took it to Cummins Cal Pacific and described the same symptoms - Fan running at full speed all the time (tons of dust every time we pulled into an unpaved campground) and they found the failed part. I can't remember exactly what it was called, but it was a part that opened and closed a valve on the hydraulic lines that drive the fans. At least it was stuck open so we weren't overheating.
If you need more details I can call Cummins and ask them.
2003 Country Coach Intrigue, Cummins ISL 400
Toad: 2006 Jeep Wrangler Unlimited (LJ) toad, with just a few mods...
Other rig: 2005 Chevy Silverado 3500 Duramax Dually / Next Level 38CK Fifth-wheel Toy Hauler w/ quads, sand rail, etc...
crasster
Agree completely. Those side rads can totally become clogged with junk after a nice trip. Especially if you happen to any offroading areas, dusty areas, or areas infested with bugs!
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
Pogoil
Just returned from a 2000 mile trip. Side radiator was flushed before trip on return I could have filled a coffee can with the debris that I washed out of the radiator and cac. Bottom inch had about 1 inch of new debris stuck to it.
I wash mine at least 4 times a year.
Remember to use the Simple Green formula that is aluminum friendly. The regular is hard on aluminum.
Pogoil.
oldmattb
I had a similar issue. My thermostat is a wax valve which is not electric. They often become clogged with a bit of junk.
In my case, the problem seems to have been a restrictor placed by the manufacturer, to reduce head pressure of the dash AC when the AC is on and the engine cold. I drilled out the restrictor to reduce cold fan speed.
Matt B
oldMattB
1998 Monaco Windsor
moisheh
Golden: He has a side rad. They do not normally plug like rear rads.
Moisheh
smlranger
Your coach may have the Sauer-Danfoss fan controller which reads info from several sensors (3 I believe) to control the fan. If the controller fails, it generally defaults to high speed.
Or you may have another set up. My 2007 425 HP ISL uses info from the engine ECM to control a little solenoid mounted on the hydraulic fan motor to control fan speed.
2019 Grand Design Solitude 384GK 5th wheel. Glen Allen, VA
Golden_HVAC
It is probably dirty. Try using a garden hose to rinse the radiator, then spray with something like simple green. Let it soak for 1/2 hour, and then rinse with more water. ..
If you get off lots of dirt, that is your solution.
Some municipal bus lines have a full time mechanic to just wash radiators every day. One even went to the expense to make the fans reversible, and blow air the other direction for a few minutes each hour. This dislodges some of the dirt every hour.
Good luck!
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a
Porsche or Country Coach!
I havn't been everywhere, but it's on my list.
Kangen.com Alkaline water
Escapees.com
