May-16-2013 01:23 PM
May-17-2013 03:26 AM
RvnStreib wrote:
Question;
Is break drag enough heat to dissipate threw the rim to the tire to over inflate the tire?
Is 10 lb + - an average range for tire pressure during travel.
May-16-2013 04:25 PM
May-16-2013 04:05 PM
May-16-2013 03:12 PM
Mich F wrote:
Assuming you're on an E450,your GCWR for the van might be 20,000, but I doubt Four Winds rates that motor home, which I imagine has a fairly long frame extension, for more than 5,000# towing, and probably somewhere around 350# - 500# tongue weight.
May-16-2013 02:36 PM
May-16-2013 02:34 PM
RvnStreib wrote:
sh410
Any recommendations on where to get a four corner scale done. The last scale I went to was an axle scale only.(Mid West preferably)
May-16-2013 02:28 PM
May-16-2013 02:19 PM
May-16-2013 02:17 PM
May-16-2013 02:05 PM
May-16-2013 01:55 PM
May-16-2013 01:45 PM
May-16-2013 01:37 PM
May-16-2013 01:36 PM
RvnStreib wrote:
This is my first time posting and I need help.
I have on 03 4winds 31p class c MH ,2 years ago I purchased 7 new off brand tires (Mastercraft) I have now had 3 damaged tires in the inside pass. rear The tire dose not go flat it delaminates part of it. What to do now
1. larger load range tire
2. name brand tire
3. check for any thing causing damage to tire. (breaks replaced May 03)
Specs.
I am over weight
frt. axle 3780 lb - rv rate 4600 lb
rear axel 10300 lb - rv rate 9450 lb
trailer axel 5720 lb - trailer rate 7000 lb
