โOct-25-2016 08:38 AM
โOct-26-2016 08:09 AM
wredman wrote:
how do you dry out the jeep after you launch the boat?
โOct-26-2016 08:03 AM
Jayco-noslide wrote:
I think the Ford V-10 does a good job. Our 2002 30 ft. Class C has adequate but not surplus power. It tows a 2700 lb. car nicely. I'm not sure all the V-10's are the same power output. It varies with the year and all engines can be tuned to put out more or less HP.
โOct-26-2016 07:56 AM
โOct-26-2016 06:52 AM
โOct-26-2016 06:36 AM
vjstangelo wrote:
Nice set up to timmac. Curious as to why you trailer the Wrangler and not tow 4 down.
โOct-26-2016 05:45 AM
โOct-26-2016 04:21 AM
โOct-25-2016 09:12 PM
wredman wrote:
Since this seems to be the primary gas engine for motorhomes, and all applications are the same engine and power. Is there a general consensus on coach weigh where the engine no longer seems acceptable, and most people would wish they went with the diesel engine coach?
I know its subjective, and depends on the hills typically driven and we can all learn to accept the slow lane :). It just surprised me that all of these different weight coaches have the same engine.
โOct-25-2016 08:54 PM
โOct-25-2016 06:14 PM
Effy wrote:I'm with Effy on this one. My V10 31' 18,000 GVWR coach as plenty of power but if I go bigger a DP is in my cross hairs. Besides the power train there is a lot of other stuff a diesel brings along for the ride that I would like to have.
If I were looking at anything larger than 34-35' I would look at diesel. ,,,,,
โOct-25-2016 05:02 PM
โOct-25-2016 02:48 PM
DrewE wrote:
The V10 used in class C's is not the same version of the engine as used in class A's. The version used in the E series (class C's and vans before the E series vans were discontinued) has two valve heads and somewhat less power than the 3 valve version used in other vehicles. Apparently the larger 3 valve heads don't physically fit in the E series chassis.
โOct-25-2016 11:42 AM
โOct-25-2016 11:19 AM
DrewE wrote:Interesting, I didn't know that. Thanks!
