โJul-12-2015 09:10 PM
โJul-17-2015 06:10 PM
โJul-17-2015 05:57 PM
holstein13 wrote:Executive wrote:X2. This is exactly what I do and I feel Dennis has the correct theory as well.
I leave the grey open and the black closed. Moving day, I close the grey just before our showers. I then empty the black and flush with the shower water. After three flushes, I allow some shower water to fill the black then close it. I then finish draining the grey tank and I'm ready to travel.
My opinion is as you shower, do dishes etc. that water is hot to warm and anything from the shower and/or kitchen sink is still suspended in that water. By allowing it to drain immediately, you're moving those suspended particles into the sewer with the hot water. Same with soap scum. That's hot water being sent thru the sewer hose. By allowing water to sit in your grey tank for days, those suspended particles settle to the bottom of your tank where they mix with any food particles, grease or whatever from your kitchen sink. The water cools and all that mess now gels. When it's time to empty the tank, any clear water must pass over and/or thru that gooey mess before emptying into the sewer. Also, you're now sending cold water thru your hose. Hot water will keep things a lot cleaner than cold water.....Dennis
โJul-17-2015 04:07 PM
โJul-13-2015 09:09 PM
โJul-13-2015 04:43 PM
โJul-13-2015 11:01 AM
โJul-13-2015 10:51 AM
Vet Man wrote:We always keep both the black tank and the grey water tank closed and never had that problem.
The first time you take a shower and the gray tank is shut and the water starts overflowing, you have to get dressed and go open the gray. You will leave it open, until the day before you dump the black tank. As was mentioned here.
โJul-13-2015 10:20 AM
camp104 wrote:
When camping in full hookups I always keep my grey tank closed until full. When dumping the grey tank it smells worst than the black? Would it be better to keep the tank open or closed?
โJul-13-2015 10:05 AM
โJul-13-2015 10:01 AM
dougrainer wrote:
Leaving both Gray and Black valves OPEN, will cause buildup in the tanks. Worse in Black tank, but you will still get buildup in the gray tank because the heavier debris cannot flow out that small slope in the tank. Also, IF you want Tank valve problems, leave the valves OPEN. The cavity between the plastic valve slider and between the 2 seals will slowly fill with slime and debris that will not flush out and then you get valves that will NOT close completely. It is better for gray to fill to full then dump, that gets all the oils and such to flow out. Doug
โJul-13-2015 07:44 AM
โJul-13-2015 07:00 AM
โJul-13-2015 06:47 AM
"We Traveled To Alot Of Different Places While On Vacation, Until The wife Asked Directions"
โJul-13-2015 06:03 AM
