โMar-09-2018 10:39 AM
โMay-21-2018 06:13 AM
hipower wrote:
Overall it appears that heated floors are loved by those who have them, envied by those who don't and wonderful when they are trouble free. Just about like everything else in our wonderful coaches.
Normal maintenance is not difficult in nearly all cases, unless the owner is a complete terror with tools or has physical limitations. Repair type work is much more troublesome with water or electric since either medium is covered by flooring material. There just isn't any simple access to any wires or tubes. Those who say continuous tubing can't or won't leak are denying the obvious. It can and does, infrequently, but not unheard of. The highway movement of a coach introduces stresses on components we may have in our stable sticks and bricks homes that are new and different than those same components see when sitting still.
Given the choice, I would always opt for in floor heat, regardless of type. It is just so much more comfortable. Aren't we all trying to enjoy what we worked all of our live for? I know I am.
โMay-21-2018 05:42 AM
โMay-20-2018 07:29 PM
AlaskaShooter wrote:Just note the lower end Entegra (used to be Aspire - now Insignia) are LP Aquahots, not diesel. Cleaner to operate, but not as convenient for long term parking.
In doing research for a future Entegra Coach purchase, kits are available for the Aqua Hot units that contain the necessary new nozzle, filter and seals for the yearly maintenance. Also I believe I read where the units have a tool used to the igniter probes.
โMay-20-2018 01:04 PM
โMay-20-2018 12:19 PM
โMay-20-2018 09:39 AM
โMay-20-2018 09:38 AM
โMay-20-2018 07:52 AM
โMar-11-2018 07:31 AM
โMar-10-2018 07:11 PM
โMar-10-2018 01:25 PM
โMar-10-2018 10:28 AM
โMar-10-2018 07:52 AM
โMar-10-2018 06:22 AM
dougrainer wrote:I haven't ever heard of issues with them, but at the same time I would tend to agree with you. At the RV shows, I heard more negative discussions because of it than I did any benefit from the rep.Mile High wrote:dougrainer wrote:I think I am RIGHT and you are NOT. ๐Mile High wrote:
Tiffen uses electric heated floors. Entegra actually uses the AquaHot to heat the floors.
Either way - I would get them if available! They weren't available for us and those tile floors can get down pretty darn cold in the morning ๐
There is a difference between HEATED floors and what Aqua Hot does. Aqua hot is NOT a Heated Floor like people think you mean. Aqua Hot just has their floor mounted Radiators with the muffin fans blow hot/warm air ACROSS the floor at the floor level. NOT close to that 14 inch wide radiator and the Floor is NOT warm/heated. True heated floors have a 120 volt heat grid under the Tile floor and radiate the heat evenly thru out the Tile floor. While Entegra advertises they use Aqua Hot to heat the floors, I think that is a misleading statement. I researched this because I thought Entegra was running coolant lines in a grid under the Tiles. NOT a good idea as leaks are bound to happen. I found out they do not, they use the Radiator system to flow the heat across the floors. Doug
And I stated if I am wrong I stand corrected. Doug
PS still not a good system as I explained
