Heater Core
the_maleman
OMG. Did I just make the biggest mistake of my life. Guess I didn't do enough due diligence. I have bought a 1995 Holiday Rambler Endeaver LE Diesel Pusher with 37,000 miles. I need a heater core and maybe some AC work. Everyone I call doesn't want to work on it. Most say they won't work on anything more than 10 years old. If I eventually find some one here in the Denver area, I'm extremely worried about problems while travelling. Any responses appreciated.
7 REPLIES 7
holstein13
Try calling the chassis manufacturer. They have a network of authorized service centers.
2015 Newmar King Aire 4599
2012 Ford F150 Supercrew Cab
DSDP_Don
"the maleman".....You didn't make a mistake. Most everything mechanical on your coach someone will work on. Of all the things that need repair on an RV, the heater core can be a nightmare. Some coaches require unbolting the front cap and reaching in behind it to get at the heater core. It's not like a car where someone can look in a manual and see how to R&R the part. With an RV it's a figure it out as you go. Keep looking.....someone will take the job on.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
Son_of_Norway
Try Best Auto and Motorhome in Arvada. I just had my radiator and heater core done there and they did a good job. The owner, Jack, is a good guy and he will make sure that you are satisfied with the work.
Miles
Miles and Darcey
1989 Holiday Rambler Crown Imperial
Denver, CO
Big_Katuna
Keep looking. You just need to find the right guy. The big shops like Freightliner or CAT will probably do your chassis stuff but their rates will likely be $120+/hour. RV part is harder to find.
Ask some other DP owners who do they use.
My Kharma ran over my Dogma.
mabynack
I was an auto mechanic many years ago and replacing a heater core was one of my least favorite jobs. It can take a lot of work just to disassemble the vehicle to the point you can get to a single mounting bolt. I wish you good luck on this. You definitely want to find someone with experience.
Mandalay_Parr
Were you calling dealers or mobile techs?
Take it to your chassis maker. Personally I like the little family owned service companies and definitely the mobile techs.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
darsben
Try RVSERVICEREVIEWS.COM
Stay away from RV DEALERS use a truck repair
Traveling with my best friend my wife!
