Jun-12-2013 07:04 PM
Jun-14-2013 06:02 PM
Jun-14-2013 05:44 PM
Jun-14-2013 03:03 PM
Jun-13-2013 10:44 PM
Jun-13-2013 09:04 PM
ron.dittmer wrote:
I agree...that is crazy for 3 year old tires. I would discuss with the tire company before the seller.
Did the previous owner live in desert heat? Maybe a steady diet of 120 degree weather is the culprit. Still this should not happen that soon.
Jun-13-2013 08:45 PM
pnichols wrote:
Rush,
Those are terrible cracks in your photos above. You should get some $$ back from Michelin somehow someway.
What Load Range are they?
What pressures do you run them at versus their maximum allowed pressures?
What is the weight of your truck camper?
Have you been using Aerospace 303 on them every 30 days?
By the way, Michelin may just about be done producing M&S tires. Their main LT tire line appears to be M&S2. This new tire line now uses different materials for the sidewall plies.
Jun-13-2013 08:38 PM
Jun-13-2013 08:34 PM
Jun-13-2013 05:59 PM
Jun-13-2013 12:39 PM
Jun-13-2013 10:51 AM
Jun-13-2013 09:42 AM
Jun-13-2013 06:36 AM
TyroneandGladys wrote:
Covered or not they are still subjected to the heat. With us being in Phoenix we halve always changed out tires out at 3 year on all of our vehicles. Unfortunately I started to listen to people that said that was excessive. Tires on Glady's vehicle were 3 years old in January and in the last three weeks had two tire fail because of the belts separating, Tires still had 50% tread. She now has 4 brand new tires and I WILL change tires at three years I do not care what anyone says the safety of my family is not worth saving a few bucks. But that is my choice and your choice is your choice.
FYI it is not uncommon on motor homes that if a rear tire fails for it to do over a thousand dollars in damage to the body of the RV, LP lines ,water lines, brake lines and electrical wiring.
Jun-13-2013 06:29 AM
Jun-13-2013 05:25 AM
