How often have you had to add to your house batts?
Maladjusted
I have 4 six volt batts for house batteries. I have read that they have to maintained by adding electrolyte (distilled h20), but how often. Just trying to gauge whether or not to purchase the "fill kit" from CW or the like.
Use the Coach 2 weekends per month, at campgrounds, stays on shore power parked at home.
Thanks in advance,
Mal
30 REPLIES 30
Fifty4F100
RayChez wrote:
If you are hooked up to shore power all the time, you should check your batteries at least every three months and add distilled water as needed.
If the batteries are new they do not need much water, but as they get older and most RVers do not equalize their batteries because they do not know how, the batteries will start using more and more water.
You should also check your battery cells every so often with a hydrometer to see if you have any bad cells. Once you have a bad or shorted cell, you will need to change the battery out.
I use tap water in my batteries, always have. Of course Memphis water is VERY good. An electrician friend told me years ago that distilled water is OK, but not absolutely necessary.
Glenn in TN
2008 Ford F150 King Ranch
2012 Allegro Breeze BR32
2017 Mini Cooper (future toad)
Fifty4F100
wa8yxm wrote:
Varies depending on converter and age of batteries.
When my rig was new... annually.. 8 years later 3-4 times a year, Some folks every 1-3 weeks.. (They need to upgrade their converters for the most part) but that gives you the range.
I would check once a month till you know better.
Where might I find my converter? I have to fill with water almost every month when I keep mine plugged into a power supply.
Glenn in TN
Peralko
I stopped adding water to the house batteries since I got the AGM batteries!;)
Peralko
USAF Retired
2000 Prevost Marathon H3-45
2006 Nissan Maxima
imgoin4it
duplicate post
Howard,Connie,& Bella,
One spoiled schnauzer
2007 Newmar KSDP
4dr Jeep Wrangler
imgoin4it
Check them once a month. may not have to add water but check them anyway.
2007 Newmar KSDP
4dr Jeep Wrangler
RayChez
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar 3126-E
3000 Allison Transmission
Neway Freightliner chassis
2017 Buick Envision
hipower
Usually check them monthly and need to add water 2-3 times a year. Seems to depend on how hard we use them.
mscamping
I check them the 1st of the month and give them a squirt with a baster every other month.. I don't trust myself to let them go longer and remember to check and fill..Mike Mathews..
2003 Holiday Rambler Neptune 36 PBD - ISB 300 Cummins- Allison MH2000 5 speed
2013 Equinox w/Blue Ox Aventa II & SMI Stay-n-Play Duo
FMCA 331658 HRRVC 105155 Chapter - 57- Good Sam Life Member - Coach Net - 3/4 timers
Mike & Sharon
wa8yxm
J-Rooster
When, I'm in the Pacific N.W. cool temperatures once every 4 to 6 months! When I'm in Arizona every 2 months.
The_Shadow_Nos
We are fulltimers and I add water ever month.
2005 Allegro Bus
400 HP Cummins
2005 Jeep Liberty CRD
w4phj
I trickle charge about 1/2 amp and have to add about 2 quarts every 6 months to my 4 house batteries.
2021 Winnebago View 24J
2021 Ram pick up
2015 Jeep Wrangler Unlimited Sahara
Ham Radio Extra Class Volunteer Examiner
FAA A&P License
1969 Plymouth Road Runner
w4phj
2021 Ram pick up
FAA A&P License
full_mosey
That is like saying jumbo shrimp!
Distilled water is what you want as it devoid of any electrolytes.
The acid stays in the battery and does not evaporate with the water that is lost. So yes, distilled water is what you add.
HTH;
John
