Apr-05-2016 10:50 PM
Apr-06-2016 09:15 PM
Apr-06-2016 07:13 PM
Apr-06-2016 04:17 PM
AllegroD wrote:
Let me point out that the OP said No shore power.
I am from around the Tacoma area.
Are all 6 of the batteries on the coach 12v system, or are some on the chassis 12v.
You could try the heaters and light bulb. You will need to watch your batteries. Below 12.2v and you will start shaving life off the batteries. A small space heater may not keep the interior warm enough without constant running. A 100w light will also chew up some power. I think you are going to find out that after a very few hours to days, your batteries may die.
Solar. How large is the solar? What will you do if there is 2-4 days of clouds and rain/snow? What will you do to keep panels clear of snow?
I'd dump water and blow it out. Make sure to get the pump. Pex pipe is not the freezing hazard. plastic joints, especially a low one, is the weak spot.
My FW tank is 70 gal, so if I dump a half full tank then that is 35. I would rather do that then to lose a water line. I did have a frozen ice maker line.
Apr-06-2016 04:03 PM
Apr-06-2016 03:38 PM
Apr-06-2016 02:14 PM
Apr-06-2016 02:10 PM
Apr-06-2016 01:32 PM
Apr-06-2016 12:40 PM
Apr-06-2016 12:31 PM
Apr-06-2016 11:34 AM
Apr-06-2016 09:07 AM
corvettekent wrote:
Don't forget to get the water out of your water pump.
Apr-06-2016 07:50 AM
Apr-06-2016 06:56 AM
