IOTA Transfer switch seems to be sticking
toban
I have a DSDP Newmar. I have noticed when I start my generator, the transfer switch clicks after starting but it doesn't click right over for a contact. I lightly tapped the top of the box and it clicks further to make a contact. I shut down the generator and started it again to activate the transfer switch again and it clicks right over.
What does one do to fix this situation? Can you clean or lubricate the swivel points inside? It doesn't take much to have the contacts come together with a light tap on top of the box. As I said, I've repeated this process over and over and it clicks right over after the initial tap.
Any suggestions for me?
Toban
14 REPLIES 14
winepress
dougrainer wrote:
bullydogs1 wrote:
Doug
I value your wisdom and knowledge but my friends IOTA switch heated the contacts and a burning smell ensued...enough to scare anyone..that's why I called it a ticking time bomb.
It was the LOOSE connections that caused the problem, NOT the Iota. Doug
If you use this transfer switch(IOTA)you need to periodically check the terminals. The problem is the terminal bar, it is made from aluminum and the wiring is copper, which is not a good mix. Add that the enclosure is made from plastic is another problem. Tick, Tick.
Try to live up to your dogs opinion of you.
dstock50
Depending on use all relay contacts need to be burnished, my IOTA delay circuit card failed, they replaced it quickly, they also have a small over ride switch on the circuit card, WARNING make sure all power is off when working on this box.
toban
Since I was the original poster, I thought I'd pass on the message that I had replaced my IOTA transfer switch with a Progressive Dynamics 50 AMP switch and it works great now with the generator. The allen screw connectors were tightened well.
Thanks for your help and answers.
Toban
dougrainer
bullydogs1 wrote:
Doug
time2roll
bullydogs1
Doug
Stuart and Stella Denning
2016 Entegra Aspire 42RBQ
The 3 Bulldogs (Daisy, Sylvie and Stashie)
2018 Equinox Diesel (TOAD)
Corkey05
Toban ... Any power to your coach has to go through the transfer switch. The switch decides when to move the source to generator or shore power. So, if you use the coach, you use the switch.
The only time it's not in the loop is if you're running on Inverter (if you during boondocking).
It might not be your problem, but it's a known problem with a known safety issue bad enough for an industry wide recall.
2008 HR Endeavor PDQ - Ford Edge 4 Down
FMCA F374292
toban
Yes, I have a 2004 DSDP but the transfer switch from the generator has not been used that much. I only have 130 hours on the transfer switch from the generator. The rest of the time I've been plugged in.
The switch just started to stick now. Initially, it does not want to click right over to make a contact but does when I gently tap the top of the box. I then have tried it many times after by shutting down the generator and starting again and it switches over no problem many times tried after the initial start.
The points haven't been used that much with that many hours on the generator.
Toban
dougrainer
bullydogs1 wrote:
I switched mine out with another and IOTA would not make good on it until it actually failed.....it is a ticking time bomb...
Right. What will happen if it fails? NOTHING. No Ticking Time Bomb or any such type problem. It will just FAIL, NOTHING ELSE. The Recall had to do with the OEM INSTALLS, NOT a fault of the Iota part. The OEM's were NOT torquing the screws correctly and the 120 wires could then possibly be loose and cause arc'ing and generate heat. I sometimes wonder where the Sky is Falling people get their misinformation. Doug
bullydogs1
dougrainer
You have the 2004 DSDP? If so, I would replace the 50 amp transfer box. You could take it apart and file the relay points. Odds are the relay points are pitted from years of engaging with a load. Your symptoms point to that. You can also find just the relay's and remove the old and rivet the new ones in, but I would just replace the Complete Transfer Box. After 13 years, that is not a big cost to do. Doug
The_Texan
Here is a LINK to a post I made last week about the IOTA ATS. Mine was doing the same, as far as the contactor(relay) chattering and sticking. The IOTA is a time bomb just waiting to go off.
Bob & Betsy - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
2005 HR Endeavor 40PRQ, '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2017 Rzr 4-900 riding in 16+' enclosed trailer in back.
Where the wheels are stopped today
Corkey05
Toban
What year?
Just FYI, but NTSB recalled The transfer switch described below for Monaco coaches 2008 thru 2011. To my understanding it was industry wide.
Instructions provided by Jayco
NHTSA CAMPAIGN ID Number: 12V060000 NHTSA Action Number: N/A
Component: ELECTRICAL SYSTEM Potential Number of Units Affected: 249
Summary:
NAVISTAR IS RECALLING CERTAIN MODEL YEAR 2008-2010 BEAVER AND CERTAIN MODEL YEAR 2009-2011 MONACO, AND CERTAIN MODEL YEAR 2009-2011 HOLIDAY RAMBLER RECREATIONAL VEHICLES, MANUFACTURED FROM OCTOBER 25, 2007, THROUGH AUGUST 26, 2010, EQUIPPED WITH IOTA ITS-50R 50 AMP AUTOMATIC TRANSFER SWITCHES.
THE IOTA ITS-50R 50 AMP AUTOMATIC TRANSFER SWITCH BUS BAR AND/OR ELECTRICAL CONNECTIONS MAY BE INADEQUATE TO HANDLE THE ELECTRICAL LOAD.
Consequence:
ELECTRICAL OVERLOAD OF THE TRANSFER SWITCH COULD LEAD TO OVERHEATING, AND A FIRE, INCREASING THE RISK OF PROPERTY DAMAGE, PERSONAL INJURY, OR DEATH.
FMCA F374292
wallynm
Not sure what you mean by "click right over" but there is a built in delay. Try starting the generator and see what happens without doing the tapping routine.
Toban
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
