Keeping Front Door Open on a Diesel
want-a-be
With every little puff of wind the front door on our coach slams shut. Was wanting to know if any one has came up with a solution for this problem?
14 REPLIES 14
Passin_Thru
I am curious, Whats a bunge cord? One for a bung on a Whiskey barrel?
debandi
I would use a gas piston similar to the ones found on many camp trailers. It keeps pressure on the door keeping it open. These pistons come in different sizes. Good luck
John Spear RMCS(SW)USN RET '88
Debra is my 'nagagator'! She tells me where to go.
Enjoying our 2006 Roadtrek Adventurs RS
Executive45
Vice grips or a simple spring clamp (get it in color to match the coach) depending on how worn the dimple is....Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
Monaco Executive M-45PBQ Quad Slide
525HP Cummins ISM 6 Spd Allison
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
Bruce_Brown
Moderator
Moderator
GordonThree wrote:
I'm curious, what does a diesel motor have to do with the problem?
Simple, because they use a completely different door set up than a gasser does.
Ours worked great for years then started doing the same as the OPs. In our case the bushing had worn out. I spun a new one out on my lathe and installed it. Fixed.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
DaveG39
I had that problem, called the door manufacturer (name on door decal) and they sent, for money, a replacement scissor mechanism for the top of the door. Short time to remove old and install new.
2007 TropiCal LX towing 2012 Honda
CRV, Goleta, CA
GordonThree
352
Have the wife keep tension on it
The manatees of Halls river Homosassa Springs Fl
1985 Chevy Silverado c10. 454 stroker / 495 CI = 675 HP. 650lb of torque. Turb0 400 tranny. 3000 stall converter. Aluminum heads. 3 inch exhaust flowmasters. 2 inch headers. Heat and air. Tubed.
Lwiddis
I come up with RGโ€™s idea too....bunge cords. Might work on a gasser too.
accsys
A pair of vice-grips squeezing those two arms at the top of the door will do the trick. You can also rough up the little dimple on those arms so it isn't as smooth but the vice grips work best.
John & Doris
Doris and Robbies Blogs
2017 Cedar Creek Cottage 40 CCK
FMCA F380583, PA, Good Sams
Ivylog
It's a 2013 Phaeton 36GH...one click away under his profile. Still no help for me as I have no idea what kind of mechanism it has for holding it open. IF it's a arm like a scissor I've had good luck bending the short portion after the pivot so the dimple on it goes into the depression on the other portion with more force. I use two large crescent wrenches...others have used a large backing hammer on the bottom of the pivot while hitting the top to tighten it.
Upgraded with a 08 HR Navigator 45โ€™...
want-a-be
This is on a Tiffin motor home.
naturist
Short piece of 2x4. (Before anybody says too big, the idea is so that it is too big to miss so nobody trips over it.)
rgatijnet1
Bungee cord with hooks
wolfe10
You will need to let us know what motorhome you have for us to be of assistance.
Does it have a posi-lock?
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
