Leveling blocks slip
jjson775
When we level up with our plastic blocks, especially on a paved blacktop surface with a little small gravel, they frequently slip and it may take several tries to drive up on them. I have been thinking about getting a rubber pad of some kind to put under the blocks that would grip the pavement and not allow the blocks to move. Has anyone tried something like this?
22 REPLIES 22
Tvov
RCMAN46 wrote:
Try disconnecting the 7 way connector to the trailer.
I believe he is talking about a Class B, camper van.
What kind of leveling blocks are you using? The "lego" type? Are they extra tall?
I use wood planks that are cut at an angle along the end for the wheels to drive up on.
_________________________________________________________
2021 F150 2.7
2004 21' Forest River Surveyor
PSW
For my plastic leveling blocks slipping I just use the cheap non slip shelf and drawer liner most of us use to keep stuff from sliding around in out rigs. It works fine for me, weighs nothing and only costs a few bucks for a small roll.
Paul
PSW
2013 Phoenix Cruiser 2350
2014 Jeep Cherokee behind it
and a 2007 Roadtrek 210P for touring
RCMAN46
Many controllers apply what is called holding brake effort after a short time if the brake lights are on.
The Prodigy has a feature to disable the Hold while backing a trailer.
Use this procedure.
Reverse
When backing a trailer you can cancel “BOOST” and
“HOLD” for a period of three minutes. This can be
accomplished by pressing the boost button continuously
for five seconds with the brake pedal depressed.
GordonThree
jjson775 wrote:
The mat at Tractor Supply looks perfect! Thanks wthibeaux.
Great idea, I've had the same problem. Thanks
jjson775
Lwiddis
Interesting. I haven't experienced this but I do kick them into contact with the tires and pavement, rock, dirt etc.
dennis1
Nope. Just put it 4 wheel drive and nothing slips.
My new DRW and camper on the truck the first time.
wthibeaux
Go to Tractor Supply and get a rubber mat. There are 2 different thicknesses. Cut to size with skill saw.
Warren & Peggy
Four cats "Albert, Noble, Peaches, Lil Bit" all neutered.
2010 Chev Suburban 5.3L 3.42-2005 Chev 1500 Crew Cab 5.3L 3.73
95 Mobile Scout 25FS travel trailer
5 grandchildren
