Light Switch
Mattman1959
I recently purchased a 2007 Fleetwood Bounder 34F,We you go in the entry door their are 4 switches on the right one of them is labeled light switch.I think it should control the interior lights,But it does not seem to work anything.I checked the switch and it has power going to it and when I turn it on it has power leaving it.But not sure what to check next.Help please !! Thanks
12 REPLIES 12
Mattman1959
Thanks so much allbrandauto,That was it
allbrandauto
I have a 2007 Fleetwood bounder I have the same 4 switch it that switch controls the light to the right of the door walking in the reading light where the chair is stored turn on reading light than you can control it with switch
CG_Dawson
It's for the light fixture closest to the steps. The light is turned off at the fixture, turn it on and the light switch should control it.
Happy RV'ing!!
Greg & Jackie
2003 Bounder, 32W / Ford V10 / 2 Slides
Toad: 2004 Saturn L300, Brake Buddy
jplante4
The interior light that it controls is turned off at the light.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
dturm
Moderator
Moderator
My 08 Southwind has 4 switches (on the left side though), one is to the step, one the outside light above the door, one to the luggage compartment lights and one to the overhead lights near the driver area.
Doug & Sandy
Kaylee
Winnie 6 1/2 year old golden
2008 Southwind 2009 Honda CRV
conceptumator
Just a guess but gave you checked to see if maybe it works the light on your steps? I know it's possible to switch the backlight on Kwikee steps.
crasster
Grab a volt meter and check for continuity (Ohms) and see if the switch is working. Just put the two meter leads on each of the switch terminals and press the switch. If it changes the meter read, the switch is most likely good.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
Johno02
If inside lights all have switches built into the lights, they may all be off. My doorside light switch controls all 4 inside overheads, but they all have individual switches. With all off, the doorside switch does nothing. I usually leave one or two on, and then the switch just turns them on and off.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
Coyote74
could be basement storage lights!
Joe Taylor , Good Sam Life Member
FMCA #285032
2004 Winnebago Adventurer 38R
Life's a trip, RVing makes it an incredible journey.
enblethen
It could be the inside entry light that is also controlled by switch on the dash. Look for entry light switch on dash. Turn it to the on position then try the one by the door.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Jack_Diane_Free
Do you have outside scare lights. Could be for those. Big round lights on both sides of MH.
Pass42
could be porch light/entry light........could be the switch on the ceiling fixture is off, so even if the wall switch is on, the light won't be....
2017 Montana High Country 375FL
2015 Ram 2500 Heavy Duty, Cummins 6.7, factory tow package, factory snow plow prep package
