โMay-09-2014 08:59 AM
โMay-12-2014 11:06 AM
JQgolf wrote:
I have a related question on batteries. I also have two 6v house and a 12v chassis on my 2011 Itasca F53. Can I charge my 6v with a battery charger plugged in to generator w/o unhooking batteries from the coach?
NO...
Have never seen clear answer on this? We normally have hookups on most of our trips but on upcoming trip, we may have some one night stops w/o hookups plus a 7 day stop at Jasper NP w/o hookups.
โMay-12-2014 11:03 AM
โMay-11-2014 10:37 AM
โMay-11-2014 10:25 AM
โMay-11-2014 10:02 AM
MrWizard wrote:
With your RV it should have a good 3 stage smart charger
Why not give us the converter/inverter info, model# etc..
โMay-09-2014 09:46 PM
RoyB wrote:
Consider this handy STATE OF CHARGE chart...
Also consider this report from Progressive Dynamics on how long it takes to charge a deep cycle battery.
"Progressive Dynamics ran this test on the amount of time it took a PD9155 (55-amp) converter/charger set to three different output voltages to recharge a 125 AH (Amp Hour) battery after it was fully discharged to 10.5-volts.
14.4-VOLTS (Boost Mode) โ Returned the battery to 90% of full charge in approximately 3-hours. The battery reached full charge in approximately 11 hours.
13.6-VOLTS (Normal Mode) โ Required 40-hours to return the battery to 90% of full charge and 78-hours to reach full charge.
13.2-VOLTS (Storage Mode) โ Required 60-hours to return the battery to 90% of full charge and 100-hours to reach full charge."
This is battery charging science - not many ways to get around it...
When camping off the power grid you want to watch your battery voltage and when it gets down to around 12.0VDC (approximately 50% SOC) then you want to do a smart mode charge starting out with 14.4VDC for two hours and dropping back to 13.6VDC for another hour (three hours total) to get your battery back up to its 90% SOC. Then the battery will perform almost like it would if it had a 100%SOC. You can do around 12-14 cycles of the 50% to 90% SOC rates but will have to perform a full 100%SOC after that to keep from doing damage to your batteries.
When charging with the higher DC Voltage the battery will draw the proper amount of DC current to complete its charge cycle. Then it rest back to 12.6VDC showing you it is at a 100% SOC. Your battery will usually rest at full charge of 12.6-12.7VDC after being charged at 14.4VDC and 13.6VDC for three hours...
Something like this at any rate haha..
Roy Ken
Porsche or Country Coach!
โMay-09-2014 09:23 PM
PinkLeopard wrote:
Replaced 2-6 volt house batteries because they weren't holding a charge. Immediately afterwards voltage dropped rapidly to about 12.8. Checked water - it's ok. Charged with generator and shore power to 13.6 but they're not holding a charge.
โMay-09-2014 04:18 PM
โMay-09-2014 04:15 PM
โMay-09-2014 02:01 PM
myrtle beach rver wrote:
New question which will charge coach batteries quicker/better absent an ac charger the generator 7 kw or the alternator?
โMay-09-2014 01:59 PM
โMay-09-2014 01:30 PM
โMay-09-2014 01:13 PM
โMay-09-2014 12:49 PM
