NORCOLD Icemaker
drifterpilot
I have a NORCOLD 4-door refrigerator Model #1200LRIM.
The icemaker is leaking and making a long icicle on the left side down into my ice tray. I undid the four bolts that secures the icemaker to the back wall. I removed the two phillips screws that fasten the bottom plate to the underside of the icemaker. There are three or four wires coming through the back wall and hardwired into the icemaker. There is also a little water sluice tray to supply water to the icemaker.
We hardly use the icemaker and could do with removing it completely.
Is there a kit for blanking off the the hole the wires come through and the water supply opening.
Is this thing fixable?
Anyone know the cost for a replacement unit if I decide to put another one in?
2017 Allegro 34P
7,900 Miles, Ford V10
Winegard (in-motion tracking)
Blue Ox Avail
Brake Buddy
9 REPLIES 9
fcooper
I think you need to replace the water flow solenoid. I just had a problem like this, and replacing the solenoid fixed it. A recent post by dougrainer is where I learned of this. Here is part of his post below:
dougrainer wrote:
The Icemaker water flow thru the solenoid is "timed" by the motor. The motor moves at a specified RPM thru the cycle and when it gets to the indent for the water solenoid valve as it turns it supplies 120 power to the solenoid for that few seconds. I have NEVER in 30 years of working on any type RV Icemaker(that numbers in the hundreds) had to modify the Water solenoid timing. I would suspect you have a solenoid that is NOT closing off completely and is slowly dripping water. IF the Solenoid allows TOO MUCH water into the mold, then the excess will overflow and fall into the catch bin. It will NOT stay on top and then freeze. If the solenoid water valve is seeping then THAT small amount will slowly drip on top and then freeze and accumulate that sheet OVER the existing cubes. Remove the water line coming out of the water valve and see if you see drops of water slowly drip out. If so, replace the water valve. Doug
Fred
Fred & Vicki
St. Augustine, Florida
wa8yxm
Yes, U did and reoplaced it with a pair of Rubbermaind trays, Very happy with the result
Do not know of a block off kit but any good quality tape (Eternabond) when warm and dry should work (Even gorilla tape or just fill it with GOOP).
Before you do
When you pull the front cover off there is a screw, sits crosswise, it has a half circle with + and - signs near it.. Turn it toward Minus a full turn and see if that fixes it.. NOTE you may have to play with it quarter turn at a time.
want-a-be
We took ours out and plug the hole with poster putty (it is for putting posters on a wall) we got it at Wal-Mart. Been in there for two years.
Good Luck
Valkyriebush
Marv Hoag wrote:
Replacements are available at Lowes for about $75.00, if I remember correctly, its been a few years now. No real modifications to make it work. They do wear out over time. Others can probably tell you what make the ice maker is.
X-2, replaced mine and two friends from replacements I bought at Lowes.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
barnaclebill
ABT electronics has them, see below......
View Product
Add to Cart
+ Add to Registry
+ Add to List
Whirlpool Automatic Icemaker Kit - ECKMF94
Abt Model: ECKMF94
Regular Price $129.00
Your Price $89.00
For Whirlpool or Roper Refrigerators 1993 And Up/ Part #2155469A
In Stock | Free Shipping
2009 Monaco Camelot 42PDQ
425 Cummins
Chevy Equinox or Tracker
Blue Ox towing
lj2654
The above poster is correct. I just replaced mine about a month ago with the same one, and it was a direct fit and it works great now. My old one was original from 2001 and it was nasty where the water goes to make the ice!
2001 Beaver Contessa Naples 40
2012 Cadillac Srx
retired AirForce 1979-1992
Heisenberg
Mine is like this.
2013 Winnebago Sightseer
2017 Colorado
Marv_Hoag
2000 Monaco Windsor 40
2009 Honda Fit Sport
2012 Chevrolet Equinox
ArchHoagland
I have the same refrigerator.
Just disconnect the water supply hose that goes to the ice maker.
My ice maker water supply hose connector was under the kitchen sink.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
