When we bought our current coach last Sept the PO stated the engine oil was changed "recently" but the coach had very little use for a couple of years. Last month I had the tranny oil changed and both the engine and tranny (before changing) fluids sent out for analysis.
Both came back with excellent results but I've decided to start an annual fluids sampling program but I'm unclear as to exactly what to do with the information or how to compare it to history or standards. I suspect for the engine, it can help clarify just when the oil needs to be changed. Using the Cat procedure for hours and load, that would equate to once every 4 years based on my driving....seems to long but yearly seems to short.
Right now I'm leaning towards JG for the sampling but they over 3 services and I'm unclear which I should use.
My engine is a Cat C-12 505 HP 36 qt sump.
The Tranny is an Allsion 4000 with the shallow sump and Transynd
Both have 91,000 miles.
Any clarification and info from others on a sampling program would be much appreciated.
Dick
2002 43' DP Beaver Marquis Emerald Cat C-12 505 HP, 1600 Tq
2003 Jeep Grand Cherokee Overland ---toad
