rgatijnet1 wrote:
You have done a lot of maintenance so I would look for something that could have loosened a plug, or frayed a wire, that shuts off power to the ignition. You don't say if the dash goes blank which would indicate a loss of power to the main control panel or if just the engine quits which could be a loss of power to just the ignition/ECM circuits.
Go back over any work that was done around the engine compartment and 12 volt circuits that keep the engine running.
This would be my first bet as well. Yes, you can look at the OBD1 port, but most likely you are loosing power somewhere.
If you really want an OBD1 cable, you can build a circuit for about 15 bucks in parts, however finding a laptop that still has a serial port is rare. Find a USB to serial adaptor that is tolerant of the odd baud rate is hit or miss. At this point in the game, you are probably just best off to buy one here:
http://www.aldlcable.com/products/aldlobd2u.aspOnce you have the cable, the best program for reading the data is:
http://www.tunerpro.net/downloadApp.htmThis program is just a generic skeleton that requires a plug in that will interpret the data, which you can download here:
http://www.tunerpro.net/downloadBinDefs.htmDownload the datastream definition for $OE. The program is mainly designed for tuners so it has a bunch of features for burning chips, and other things you are not likely to use. However it is the most comprehensive software out there. The learning curve is pretty steep at the beginning, but once you understand the concept, it all makes sense. Eventually you can create your own dashboard layout, so parameters are easy to see. This is what I run and have burnt several chips for my ECM.
One other possibility is a bad ignition coil, especially if heat aggravates the problem. Bad coils will usually start right back up again, but die quickly. Once the engine cools, then they recover and work fine till things heat up again. They do not give any warning, and normally do not throw a code. If you suspect the coil, when it dies, you can unbolt the coil from the engine and isolate it from ground. If the engine runs, but then dies as soon as you touch ground, then you know the coil is shorted.
I should also add that it is highly unlikely the ECM is bad. By 1993, the ECMs were pretty stable in GM vehicles.
You do not have a crank position sensor in that vehicle. That is only used for sequential FI. Since you have a TBI, the ECM does not care what position the crank is in. It just monitors the Dizzy to know when to fire.
IRV2
