Propane Alarm
rvdogmom40
DH was preparing our 04 PW for the first trip of the season. I planned to have a "girl's getaway --just the dog and I. As I was working the propane alarm started going off. Previously I had tested the stove by briefly turning it on. There is no odor in the PW or out by the tank. Seems like I remember from previous postings that these alarms occasionally fail (ours is original dated 8/03).
DH unscrewed face plate and found wires "crimped" and not joined with wire nuts. Is it a big deal to DIY? I don't want to be jolted out of sleep in the middle of the night and not be able to stop the noise. Nor do I want a gas leak.
Any advice? Thanks in advance.
8 REPLIES 8
dreed
Mine failed last year on my 04. I didn't even know they had a time limit. But no big deal to replace. The original manufacturer went out of business and the holes of the replacement don't line up just right but it's just 2 wires and you can recrimp or even use wire nuts I suppose.
Dave 04 P/W Excel TD
fla-gypsy
An 03 unit should be replaced. They have an exp date
jjrai
If it is a low voltage alarm, you can cure it by turning off power to the alarm for a few minutes. If you turn it back on and get no alarm, you had a low voltage situation. If it continues to beep, it needs replacing.
ernie1
Had the same problem with ours in our 2005 PW Excel when it was brand new. Phil at PW sent me a new replacement which I changed. The next trip, in the middle of the night, it went off and I thought I was going to have a heart attack! No, there was no gas leak, we don't have a dog and no beans for dinner! Oh and the wife uses hair spray in the morning only.
After some research and tinkering, I located an adjusting screw and and "toned" things down so that it works fine now after some testing. But, I still have not reattached the stupid thing because I don't think my heart nor my wife's can take the jarring shock in the middle of the night when I'm deep asleep! Yup, I'll take my chances!
ffjeff
Had the same issue with our 05 Plateau last year. Just replaced it as the CCI company is out of business.
ol__grouch
How much is peace of mind worth? Get a new one and sleep easy.
Honk if you love Jesus.
Text if you want to meet him.
Old-Biscuit
Was it a constant beep or just an occasional chirp?
Constant beep is ALARM
Occasional chirp....low battery voltage or failing unit.
8/03 RV.....replace. It is over due.
johnrbd
There should be an expiration date on the back of the alarm. IIRC, 5 yrs. I recommend replacing the unit now and be done with it for a while.
