Rattle/play in hitch attach
supercub
I have a drop down reciever that slides into the motorhome reciever and then the tow bar slides into the drop down, hence I have two pin points. The holes are NOT eaten out, but I do have a enough play that I get some rattle in the two recievers. Is there a way to minimize or eliminate this play/rattle? Thanks
Brian
13 REPLIES 13
wilpower
This is what I use
glamisorbust
stripit wrote:
I drilled a 5/8 hole about 1 inch from the open end of the receiver and ran a tap through it and then screwed a bolt into the hole. This puts pressure on the inserting receiver and removed any wiggle or noise. This was for my bike rack. When I needed to tow something heavier on another hitch, I welded a nut to the threaded hole so I had a bigger bite for the bolt and that was easy to do. A couple of tack welds and it was done. I carried a small crescent wrench to tighten or loosen the bold. No noise or wiggle when the bolt was tight.
This is exactly what I did, only with a 3/8" bolt. Worked perfect.
1999 Holiday Rambler Endeavor 38'. Cummins ISB 275, allison 3060.
Toys pulled: 22x8.5 open deck PJ flatbed. 5200# axles. Sand car with ecotec engine. Multiple 1980's ATC's(3 wheelers). We're duners!
stripit
Stacey Frank
2016 Tiffin Allegro Bus 40AP
2019 Tesla Model X
2015 Cadillac SRX we Tow
1991 Avanti Convertible
CA_Traveler
wolfe10 wrote:
Here is what I use: http://roadmasterinc.com/products/accessories/hitch/quiet.html
With the drop down adapter I use 2, $25 each.
2014 Grand Cherokee Overland
Bob
wolfe10
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Fiesta
I wedge a piece of thin aluminum or steel between the receiver and hitch square hole. But this can make it hard to remove the receiver for different receivers. Tape sounds (pun intended) the easiest/cheapest.
Travelin2
This is what I use...http://roadmasterinc.com/products/accessories/hitch/quiet.html
John & Gloria
South West, Florida
2009 Leisure Travel Serenity
ArchHoagland
Had the same problem when I used to pull a travel trailer.
Bought a thingamajig that was supposed to cure it....Finally just ignored it.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
wa8yxm
In my case I have a bicycle carrier mounted on the custom modified drop receiver.. Thus I really do not want it "Rattelling" around as it would toss the bike about rather firmly.
The Blue Ox Hitch Immobilizer fixed it solid (Only it was called an Anti-Rattle clip when I bought it)
The custom mod
Blue ox welded a "tong" on the top of it for the hitch mount bicycle carrier to fit on. Works great. They can do wonders when you visit the factory with your problem.. Nice campground there too.
CA_Traveler
I was getting some wear with the drop hitch and installed 2 of the Roadmaster devices at $25 each.
Mine was getting harder to remove due to the hole flare that was developing.
Bob
mscamping
I used 2 to 4 rounds of plastic tape to help with this.. If you take it off and on this won't work, I leave mine on all the time.. Mike Mathews..
2003 Holiday Rambler Neptune 36 PBD - ISB 300 Cummins- Allison MH2000 5 speed
2013 Equinox w/Blue Ox Aventa II & SMI Stay-n-Play Duo
FMCA 331658 HRRVC 105155 Chapter - 57- Good Sam Life Member - Coach Net - 3/4 timers
Mike & Sharon
RognBon
Blue Ox also makes one for their tow bars.
RognBon
1997 Monaco Dynasty 40'
Cummins 8.3 325 HP
2008 Ford Edge Toad
Travelr
Roadmaster makes a Quiet Hitch.. From Roadmaster website: Quiet Hitch stops sway and wander before it begins. Quiet Hitch eliminates any free play between the receiver and the tow bar (or bike rack, ball mount or whatever you insert) for a solid, seamless connection. Consistent pressure keeps your towing combination tracking straight through crosswinds, curves and sudden maneuvers — all with considerably less effort on your part.
They are not the only one who has such a part.
Ken Cash
