โSep-27-2013 04:20 PM
โSep-29-2013 11:23 AM
โSep-29-2013 10:31 AM
stripit wrote:
I drilled a 5/8 hole about 1 inch from the open end of the receiver and ran a tap through it and then screwed a bolt into the hole. This puts pressure on the inserting receiver and removed any wiggle or noise. This was for my bike rack. When I needed to tow something heavier on another hitch, I welded a nut to the threaded hole so I had a bigger bite for the bolt and that was easy to do. A couple of tack welds and it was done. I carried a small crescent wrench to tighten or loosen the bold. No noise or wiggle when the bolt was tight.
โSep-29-2013 09:04 AM
โSep-29-2013 09:03 AM
wolfe10 wrote:With the drop down adapter I use 2, $25 each.
Here is what I use: http://roadmasterinc.com/products/accessories/hitch/quiet.html
โSep-29-2013 06:05 AM
โSep-29-2013 05:26 AM
โSep-29-2013 05:09 AM
โSep-28-2013 10:10 PM
โSep-28-2013 06:53 AM
โSep-27-2013 04:59 PM
โSep-27-2013 04:49 PM
โSep-27-2013 04:39 PM
โSep-27-2013 04:33 PM
