โDec-18-2015 09:26 AM
โDec-21-2015 04:45 AM
msmith1199 wrote:Belgique wrote:
We just installed Alure Ultra and did not remove the slides. A pro did the install for $1K labor. Fantastic job. Best $1K I ever spent.
Just curious, I was looking at installing this too, but per the manufacturer specs, you are only supposed to put this flooring in a location where the temperature can be maintained between 55 and 85 degrees. That's usually fine in most houses, but unless you live in your motorhome can you always make sure the interior temp stays in that range?
โDec-20-2015 05:41 PM
โDec-20-2015 05:38 PM
โDec-20-2015 04:29 PM
โDec-20-2015 08:17 AM
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
โDec-20-2015 05:19 AM
โDec-20-2015 04:14 AM
โDec-19-2015 08:08 PM
โDec-19-2015 08:20 AM
Teacher's Pet wrote:Dale.Traveling wrote:Teacher's Pet wrote:Was this your COACH?
The Tiffin Service Center in Red Bay AL. Pulled our DS slide and replaced the floor, and then reinstalled it in about 2.5 hours. However it involved a stationary hoist, plus a crane rail, built up floor and 4 workers.
Yes it was see blog here for pix from 10/27/2012
โDec-19-2015 04:43 AM
โDec-18-2015 04:54 PM
โDec-18-2015 04:41 PM
โDec-18-2015 03:18 PM
chucl66 wrote:
I would like to replace carpet. Does the slide ,LR, need to be removed? It is a raised slide.
Got an estimate from one person, he wanted $1400., labor because it would take three hrs., at 90.00 per hr. to remove, replace slide.
Anyone done this without removing the slide.
Suggestions for replacement, allure, vinyl, etc?
Thanks,
Chuck
โDec-18-2015 02:07 PM
