Mar-01-2014 03:59 PM
Mar-02-2014 10:51 AM
Old-Biscuit wrote:NaViDa wrote:
Water source......only takes a few seconds to turn off. $$$$, time and frustration to repair due to broken fitting flooding RV while gone.
Power.....never trust that power pedestal has been properly wired/maintained. Especially on a 50A receptacle. Open neutral, reversed polarity, correct voltage. Testing can be done with a meter or via a surge guard device.
Fridge....off level operation disrupts the flow of cooling medium which can then be overheated and plate out on inside of cooling unit tubes. Damage is accumulative, permanent and non-reversible
Checking batteries....converter (charger) can overcharge and boil water out of batteries. Routine check of level/topping off as needed will prolong life of batteries. Monthly check until you know how your charger maintains. Some are very good, some so-so.
I still dont get why i need to turn off my water source outside when i leave for a few hours?? I mean actually leaving the rv since i'm assuming you're saying this because of the fact we're talking about what to do when if i leave the RV to go out and run errands??
And what is this "pedestal"??
And the rest you're saying, i'll need someone to explain to me in person because i am not seeing what you're saying if there isnt an image i can view.
I still paint by numbers:h
thanks
So you're gone seeing the sights and come back to water running out your door/slides because a plumbing fitting inside your RV broke/blew off.....flooded RV when all it takes is to close CG faucet to hose before leaving!
Pedestal...that would be the power source that you plug your power cord into at a CG. NEVER assume it has been properly wired or is is good condition. Test it with a meter.
A surge guard is an electric device that you can purchase (either a portable type or a hardwired type) that will automatically check the power source for improper wiring and voltage, will trip power to RV if voltage goes to high or too low
Check out this one from Progressive Industries.......LIFETIME Warranty
LINK
Fridge....level your RV and you won't have off-level problems with fridge
Batteries...check the water levels every once in a while and top off with distilled water IF needed.
Mar-02-2014 10:23 AM
thanks
Mar-02-2014 10:22 AM
DavisK wrote:Dale.Traveling wrote:
Summer thunderstorm blew thru and filled it up with water (didn't drop a corner when I set up also).
How do you dip the corner of a power awning?
Mar-02-2014 10:13 AM
Mar-02-2014 08:03 AM
Mar-02-2014 07:58 AM
Branson in Tucson wrote:
Found handle at Wal Mart in Rv section
Mar-02-2014 07:56 AM
NaViDa wrote:
I'm so glad i asked about the awning before our March winds hits Vegas!
I went to bed not worrying if i'd have to get up in the AM to roll it back up in the wind and rain, since thats here too, as well.
Thank you all!
I do have a few more questions about what was stated below here?? Could you give more details as to what you're saying and why??
Thanks!
Turning off water source when leaving
Checking power pedestal PRIOR to hooking up
Leveling RV prior to operating fridge
Checking batteries water levels/state of charge
Mar-02-2014 07:40 AM
Mar-02-2014 07:30 AM
Mar-02-2014 06:20 AM
Mar-02-2014 06:19 AM
Mar-02-2014 06:13 AM
Mar-02-2014 04:51 AM
Mar-02-2014 04:45 AM
