RV Blows Tire Causing Roll-Over Video
timmac
No one was killed by this, only minor injury, check your tire for age and air..
https://youtu.be/9LkLeljt4t0
๐Ÿ˜ฎ
120 REPLIES 120
Bucky1320
shaneperch wrote:
Effy wrote:
Haven't we been through this the last 2 times this topic was posted?
Ask the guy who lost that motor home that question
Geeze he has to be tired of rolling these things over!
1999 Harney Renegade
Mostly used for overnights at the drag strip.
Executive45
The truck driver stated HE was going 70mph. Estimates on the Moho was, IIRC, 80mph based on the 13 second video counting the number of center line stripes he passed while on tape. Way too fast for conditions AND speed rating of his tires...glad they weren't killed but the onus falls directly on the driver...:S
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
Monaco Executive M-45PBQ Quad Slide
525HP Cummins ISM 6 Spd Allison
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
Bucky1320
First time for me!:) Sometimes it makes us feel better to reason that it wouldn't happen to US. "I don't drive that fast." "I know what to do when a tire blows." Whatever....it makes us FEEL safer.
This video is a good reminder of what CAN happen. Let's stay on our toes and safe folks!
shaneperch
shaneperch
Bucky1320 wrote:
shaneperch wrote:
THe guy was going way too FAST!!!!!!!
How fast was he going?
Faster than that semi, you know how fast they go He was passing pretty fast.
Effy
2013 ACE 29.2
Bucky1320
shaneperch
Cloud_Dancer
When viewing it "frame-by-frame"/start-stop, it's obvious that the driver did NOT instantly hold the steering wheel at the appropriate/necessary angle of turn(slightly to the right) that it would've taken to maintain control.
Look, I'm only pointing out ONE of the most important steps to take at the first hint of a left-front tire failure. Yes, we've previously discussed the other important steps.
It remains to be seen if there's anyone who can actually do it.
Willie & Betty Sue
Miko & Sparky
2003 41 ft Dutch Star Diesel Pusher/Spartan
Floorplan 4010
Blazer toad & Ranger bassboat
Bucky1320
Aweful easy for me to sit here and say it could have been avoided. But there are times for me when we are cruising and easy driving. Maybe both hands on the wheel, but maybe taking a drink or itching my ear or just resting one hand. If you aren't expecting it, it isn't hard to jerk the wheel out of one hand.
JayGee
Thanks for sharing, always a good reminder to check the tires and try to avoid this if you can. Looks like the guy did a pretty good job until the cable flipped him.
Jaygee
2005 Bounder 35E on F53 chassis
Mr_Mark1
Actually, the guy had the motorhome up straight parallel to the cable guard..... the cables caught onto something under the motorhome causing it to flip (strictly my opinion).
If you use the start stop button on the video, you get an almost frame by frame view. Just as the guy gets through the cable guard, you can see the cable snap the ground (causing a dust cloud) as it catches under the motorhome. That's when the motorhome flips.
Also, watching the video 'frame by frame', you will see just as he passes the big-rig, he turns on his right turning signal which might indicate he only had one hand on the wheel. At that very second, the coach swerves to the left and you will see the tire carcass roll under the red truck.
The guy applies the brakes a couple of times as you can see the truck brake lights illuminate. Amazing that the red truck stayed attached and all four wheels on the ground.
Safe travels,
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
K_Charles
The flat didn't cause the rollover, driving off the road did. Many people have flat tires while driving and they just stop and change the tire.
mike_brez
OMG not this one again.
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
gbopp
This video has been posted multiple times on the forum.
But, it's always a good reminder to check your tires.
Our Southwind is going in for new tires next week.
